Old 04-03-2008, 04:26 PM   #1
irondiezl3
irondiezl3's Avatar
diffaculty hub ASSEMBLY
How Hard Is It To Change The Hub Assembly 04 Alero 15inch? FRONT PASSANGER
Old 04-03-2008, 04:29 PM   #2
surreal_awakening
surreal_awakening's Avatar
front or rear? rear is 4 bolts holding the hub/bearing assembly on. front you have the bolts, plus the large hub nut and you have to press the axle out of the hub.
Speaking of hubs, I am trying to get the rear hub/bearing off my spare knuckles so I can start assembly of the new stuff and god dammit I can't get it off. Took the bolts out, but it doesn't want to budge. Even the BFH won't remove it. All the stuff I have says it's only 4 bolts....anybody got any ideas? I've changed the front before, never done the back.
Old 04-03-2008, 04:37 PM   #3
alerored04
alerored04's Avatar
Slide hammer is your friend on the rears. The BFH works well on the fronts but I would not use the slide hammer there for fear of separating the cv.
My car breaks alot.
Old 04-03-2008, 04:38 PM   #4
AGT
AGT's Avatar
It's not real hard but it helps if you have access to an impact hammer.
Have a good day
Old 04-03-2008, 06:09 PM   #5
Theres a how to around the forums somewhere search wheel bearings
Also note the $20 35mm socket with 1/2" breaker bar will work on the front axle nuts.
Old 04-03-2008, 07:34 PM   #6
alerored04
alerored04's Avatar
/\ It needs to be a deep well.
My car breaks alot.
Old 04-03-2008, 07:38 PM   #7
True that.
Its the $19 one
Old 04-03-2008, 10:10 PM   #8
surreal_awakening
Slide hammer duly noted. Already have the socket. And I have a BFP, a nice 2' long 2" dia. steel pipe with a 90 elbow on one end, which gets me plenty of leverage to break loose those tight nuts and bolts. And when not being used as a tool, it fits nicely down by the side of the driver's seat in my Jeep, in case I'm having a "Falling Down" moment during my daily commute
Old 07-13-2008, 02:24 PM   #9
spinalator
spinalator's Avatar
spinalator is on a distinguished road
Crap I have a 32mm socket, but I guess I will look in dad's tool chest for a 35mm. That is a lot of cash for one socket you will never use again. (unless you have a lot of friends with grand ams and aleros)
spinalator is offline   Reply With Quote
Old 07-13-2008, 05:48 PM   #10
alerored04
alerored04's Avatar
35mm will not work and I doubt your dad will have one. That nut is very tight and 3mm too big will round it off. Spend the money, you are still cash ahead than if you had the dealer do it.
My car breaks alot.
Old 07-14-2008, 01:06 PM   #11
Worked perfect on mine! 32 is to small.
I have the first version of spindle nuts.
Old 07-14-2008, 02:26 PM   #12
FrankTheTank
FrankTheTank's Avatar
FrankTheTank is an unknown quantity at this point
the socket for the axle nut is a free rental tool from autozone...no need to buy it.
FrankTheTank is offline   Reply With Quote
Old 07-14-2008, 02:46 PM   #13
^agreed. unless you plan on doing it a few times....
Old 07-14-2008, 05:14 PM   #14
alerored04
alerored04's Avatar
It's worth buying if you plan on keeping the car. I am on my 6th wheel bearing. It is getting rediculous.
My car breaks alot.
Old 07-14-2008, 11:16 PM   #15
Whitetigerboi83
Whitetigerboi83's Avatar
Whitetigerboi83 is an unknown quantity at this point
Send a message via AIM to Whitetigerboi83 Send a message via MSN to Whitetigerboi83 Send a message via Yahoo to Whitetigerboi83
its a 1&5/16 in socket and hard to find
Whitetigerboi83 is offline   Reply With Quote
Old 07-15-2008, 10:35 AM   #16
o_O stock here, is everyone buying crap hubs?
Old 07-16-2008, 01:02 AM   #17
alerored04
alerored04's Avatar
I think I just have crap luck.
My car breaks alot.
Old 07-20-2008, 02:46 AM   #18
spinalator
spinalator's Avatar
Dad only has SAE sockets, not metrics that big. So will a 1"5/16 really work? He has sockets for his tractors that go up to 2"
The two stores I looked at had 34mm sockets and 36 but not 35...
Old 07-20-2008, 09:19 AM   #19
Whitetigerboi83
yeah our system at advance auto says 1"5/16 and my step dad has his own shop and he said the same
Old 07-20-2008, 09:50 AM   #20
when i did a friends grandam, i used a 36mm. i got it from autozone, it was in stock. worked like a champion.
