Old 04-06-2008, 11:18 PM   #1
sofa
sofa's Avatar
sofa is an unknown quantity at this point
Send a message via MSN to sofa
EGR code
hey everybody long time no see im having problems with the ho obv. im wondering if anyones thrown an egr code and did you just replace it car shuts down accelerating..and also the worst part my car is loerd and when i hit pot holes is just shuts down no miss fire just shuts down and its getting dangerous est. on the highway i have to throw it into N and restart andbody hadthis problem loose connection or what? looks like the ho is dieing with 230 000km
thanx guys
sofa
Straight.From.Steel.City
http://www.cardomain.com/ride/2313940 http://www.myspace.com/kowch
sofa is offline   Reply With Quote
Old 04-07-2008, 12:29 AM   #2
Did you replace it? I think it's right on top of the motor so it's not too hard to do.
Never heard of the car shuting down becuase of a bad EGR, unless yours is really bad
(Post 11,000)
Old 04-07-2008, 12:31 AM   #3
You most definitely have to replace it if you get a Range/Performance code.
Old 04-07-2008, 12:44 AM   #4
jackal2000
jackal2000's Avatar
it will probably take you all of 2 minutes to replace. it sits right by the brake fluid resevoir. it does require 2 gaskets, but if they arent in bad shape i wouldnt worry about it. i dont think there are any torque specs on the bolts either.
Old 04-07-2008, 11:58 PM   #5
Pacho
EGR delete if you dont ever want to buy an EGR Valve again. www.milzymotorsports.com
Talk to Mike about this.
Old 04-08-2008, 12:17 AM   #6
jackal2000
jackal2000's Avatar
i had no idea the egr valve was so expensive. i just looked it up on autozone.com and its listed @ $253.99. the egr delete is cheaper (around $130 + shipping for the delete kit and the new pcm) and is permanent so i would recommend that route.
Old 04-13-2008, 10:58 PM   #7
sofa
sofa's Avatar
alright anx alot guys appretiate it alot....at least its suny enuff to do sum wrenching outside
Old 04-17-2008, 02:05 AM   #8
Tighten the nuts to 30 N·m (22 lb. ft.).
Old 04-19-2008, 06:29 PM   #9
or you just cut a little piece of aluminum to cover the manifold after you saw it off for about $10
