Old 05-08-2004, 12:40 AM   #1
StealthAlero99
ok.... i need a picture of where you guys put ur rear neons (underbodies)... i think i have to make L brackets in order for them to fit right... but if anyone has a pic of how they did it, that would be great.... thank you
-Chris
Old 05-08-2004, 01:40 AM   #2
wy3134
I dont have a pic, but what I did was used some thin wire and just put the neon light on top of that metal object that sticks in from the bumper, its directly above the muffler, and I just tied that wire together, although the stock exhaust blocks some light on the drivers side, I plan to fix that when I get an aftermarket exhaust, and suprisingly with how far up it is, it still has very good lighting and all, and with this setup I dont have to worry bout heat damaging the neon tube or anything.....if you wanna know how i ran the wire, lmk
Old 05-08-2004, 02:23 AM   #3
bigd6983
I did what wy3414 did at first, but after it being like that it bugged me that the install was half ass so what i did was drill the holes in the metal and because i couldnt find a screw that wouldnt strip so i put plugs in and screwed into those and it holds up really good, no worrys about it at all.......
Old 05-09-2004, 10:54 PM   #4
StealthAlero99
How did you run the wire? thanks
Old 05-10-2004, 12:04 PM   #5
1WhiteOSV
here's pics.....hopefully they help (copy/paste link)
http://www.geocities.com/glowin02alero/neons.html
Old 05-10-2004, 12:40 PM   #6
bigd6983
different ways to run it, inside the covering of a rear tire deflector then you can go into the side skirts or zip tie to a side neon of you have one, then run it with the side all the way to your power
Old 05-10-2004, 02:04 PM   #7
StealthAlero99
b-e-a-utiful! thank you, that is exactly what i needed
Old 05-12-2004, 12:38 PM   #8
StealthAlero99
well i mounted it with brackets, sorta how ^^^ did on his website, but i ran the wire with the brake line (zip ties), will that be a problem, i don't see anything that it could get caught in or anything...
Old 05-12-2004, 12:40 PM   #9
ptrudel
Designated Drunk
that's what i did, and the wires were ok...as for the tube tho, that's another story...
I'm baaaackk
