Old 04-28-2008, 07:49 PM   #1
Talking LED afterglow in headlights
just wondering if i were it install like 30 leds all around my headlights (to shine into the casing) this would be my little showpiece for when im doing shows with my new Oznium inferno undercar kit (http://www.oznium.com/inferno) just wondering if the leds will melt from the hid kit or if itll be ok
thanks nate
i searched first!
Update- how hard to drill through headlight casing without breaking or cracking the case?
Old 04-28-2008, 07:53 PM   #2
depends on what color you are doing.... You can't have red or blue as they can be mistaken for emergency lights and you can get busted for that. (I almost did and cop made me take my lights off)....
Old 04-28-2008, 07:57 PM   #3
no either white or well.... damn
well i might do white concidering that that is the same thing as the angel eyes i wanna get
Old 04-28-2008, 08:14 PM   #4
GoldStar611
GoldStar611 is on a distinguished road
I believe in most states underglow lights are illegal anyway, so as long as it's all being used off public-roads he could pick any color available..
I've also been told that "public" is being redefined in the transportation code as to any road made publicly available (At least in texas that is) so that includes private property without proper signage.
I doubt that your leds would melt in answer to your question, but possibly the glue/adhesive you are using.
GoldStar611 is offline   Reply With Quote
Old 04-28-2008, 08:18 PM   #5
ok.. basically i just want to do shows with my car in like parking lots and not have them on when im driving.. thnaks!
Old 04-28-2008, 08:49 PM   #6
If you do put red or whatever color, I suggest wiring them to a switch. I personally like having blue lights outside my car cause it looks neat at night. I don't have any right now, but I use to have blue LEDs in my fogs. Just wire them to a switch that way you can turn them on and off in certain areas.
Old 04-28-2008, 09:01 PM   #7
cool, will do..
do leds need regulators for the fluxuating current in a car?
Old 04-28-2008, 09:02 PM   #8
nope. they just adjust brightness accordingly. set them up for 12v, and you'll be fine.
Old 04-28-2008, 09:05 PM   #9
ok thanks!
Old 04-28-2008, 09:32 PM   #10
so youre planning on doing this?
http://www.aleromod.com/forums/showthread.php?t=14873
if so you only need a couple leds
Old 04-28-2008, 09:43 PM   #11
GoldStar611
Originally Posted by Nate's Alero View Post
cool, will do..
Unless you are buying LEDs rated at 12-14 volts then you'll need to lower the voltage to a nominal level say 3 or 4.5 volts max. Check the forward voltage rating and don't exceed that. If they are meant for 12 volts, a current limiting resistor is always handy (I think 470 ohm is defacto for current limiting).
