Go Back   Aleromod.com > Performance Related > At The Track
Old 04-29-2008, 01:42 AM   #1
Street Machine Showdown!
Street Machine Showdown, April 27, '08, (Bandimere Speedway, Elev. 5860 ft., 55-62 deg. F.)
Ran in "Sport Compact Eliminator" (street legal / DOT tires mandatory), bracket, full tree
Air filter bypassed, "full" exhaust (but no resonator), 11-12 psi boost, iced intercooler, NGK TR 55's gapped to .045 BFG Drag Radials
1st trial.................. 14.713 @ 99.25, 2.441 60 ft.
This is funny, but it kind of set the tone for the day
2nd trial................. 13.841 @ 99.82, 2.007 60 ft.
Got a new best 60 ft. and mph, for what it's worth.... only run all day with a good launch.
1st Rd....................14.088 @ 97.74, 2.199 60 ft.
2nd Rd...................13.938 @ 97.50, 2.077 60 ft.
3rd Rd....................14.105 @ 99.77, 2.226 60 ft.
In the other lane was a stock Grandam GT, running mid-17's
4th Rd....................13.918 @ 97.36, 2.123 60 ft.
Semi-final...............14.136 @ 99.40, 2.236 60 ft.
back-to-back run
Obviously reached the limit of the D.R.'s.......forgot all about the tranny
239 timeslips and counting................
Old 04-29-2008, 07:44 AM   #2
doing it up right!! keep that time coming down!
turn on that 6th cylinder, you'll run much faster
Old 04-30-2008, 02:07 PM   #3
wow, i should have stuck around longer, that's good you made it all the way to the semi finals!!!
Old 04-30-2008, 02:47 PM   #4
Vinalero
Vinalero's Avatar
If the stock Grand-am GT was doing mid 17, and it is suppose to run around 15.9; 16.0. well those are really nice times dude. What is the elevation at this track?
Old 04-30-2008, 02:47 PM   #5
nice times keep it up
Old 04-30-2008, 02:49 PM   #6
I would say some where around 5860 ft but thats just a guess
Old 04-30-2008, 02:53 PM   #7
Vinalero
Vinalero's Avatar
wooopss
and DAMN
That means this build would run close to high 12 on low elevation?
Old 04-30-2008, 02:53 PM   #8
don't forget that on altitude correction boosted cars are only a half factor so you won't see a full second or more time difference on boosted cars like you would on NA cars
Old 05-01-2008, 01:48 AM   #9
I'm not sure what was up with that Grandam, my '03 Alero ran around 17.0-17.3 up here last year......
Didn't your original '99 Alero run a 16.7 with only an aftermarket muffler and CAI?
Old 05-01-2008, 01:54 AM   #10
Yea Baby!!
Old 05-01-2008, 12:02 PM   #11
Not a fan of the hood scoop, but going those speeds I wouldn't see it. haha.
Old 05-01-2008, 02:16 PM   #12
yeah it did run a 16.7 a full second slower than the 15.7 i recorded with it at lansing 2 years previous
