Old 05-12-2004, 12:30 AM   #1
Justy311
Justy311's Avatar
Justy311 is an unknown quantity at this point
Forgive me if this has already been covered, but I am just curious on how people would go about fixing their guages to properly match back up, and also what is the typical idle speed for a 2000 gls 3.4 alero, i know mine is off cause its at 1000 rpms idling speed. I tried to put back on my indiglos and the blue is out, so had to put everything back together and now all my guages are off. thanks for readin.
Have unwanted police or sheriff items, badges, patches or uniforms, etc., you don't want, i'd be interested in them.
www.justinspolicecollection.com
Justy311 is offline   Reply With Quote
Old 05-12-2004, 12:36 AM   #2
niral622
niral622 is an unknown quantity at this point
I have a 2003 GL 3.4L and it idles at about 1100 rpms, I don't know if that little bit makes a difference, as for recalibrating the gauges...I don't know Sorry
2003 Black GL - Sedan and No sunroof
niral622 is offline   Reply With Quote
Old 05-12-2004, 04:42 PM   #3
mdodge
mdodge is an unknown quantity at this point
Send a message via MSN to mdodge
Well, if you had one of those computer digital code readers and a laptop you can see the digital output of your rpms and you could calibrate that way.
If you have to calibrate blindly the best way is to take apart the cluster and start the car. The needles will move to their current positions.
For the gas needle, the best way is to fill it up all the way beforehand. Then with the cluster open and the car started, take off and place the needle to the full status.
For temp, wait until car has completely cooled down (overnight) then make sure in cool position when car is on.
As far as speed, when the car is started, the mph needle should move just barely, slightly above the needle stop. Recalibrate until it does. Also, when you unplug the wire harness to the cluster and plug it back it. All the needles move to max and then back down. Make sure they all move to max. Ex: MPG needle only goes 120mph instead of 140, then you know its off by 20mph. You can always pass a speed detector on the highway to find out you exact mph
RPMs are hard if you don't know your own average rpms at idle. With my current mods, mine is only around 700-900rpms. I think most people average from 800-1200.
I'm sure there is a better way to do this but this is how I did it. Not very effecient, I know but maybe someone else knows how to do it better. Hope this helps.
mdodge is offline   Reply With Quote
Old 05-12-2004, 04:44 PM   #4
Justy311
Justy311's Avatar
thats great gives me a heads up and a better understanding, thank you for all your help on this one its greatly appreciated. :thumbsup:
Old 05-12-2004, 05:05 PM   #5
mdodge
Glad to be of help!! B)
