Old 05-14-2008, 01:35 AM   #1
kniedelm9490
kniedelm9490's Avatar
kniedelm9490 is on a distinguished road
Send a message via AIM to kniedelm9490
amping rear and front speakers HELPPP
so i pulled off the door pannels cut the factory connection and ran it back to the amp on and it works perfectly. but the when attach the rear speakers to the amp it cuts out the front speakers.
do i need to get an rca slpitter? becuase i have 4 rca plugs that are running to two diffrent amps one pair in each
kniedelm9490 is offline   Reply With Quote
Old 05-14-2008, 06:50 AM   #2
So you hacked up your wiring and now are encountering problems? Ouch.
Given your description it makes no sense. I would take it into a shop before you do anymore damage.
Old 05-14-2008, 12:28 PM   #3
Note to self: Make sure my kids never form a sentence like that in there life.
There shouldn't be a RCA splitter anywhere in your future. Please try to describe you problem as best and clearly as you can. There's a ton of people on here that could probaly help you out. Good Luck!
Old 05-14-2008, 12:55 PM   #4
02AleroEco
02AleroEco is on a distinguished road
Send a message via AIM to 02AleroEco
When i replaced my front and rear speakers i kept factory wiring, until i decided to rewire the speakers, and i had the same problem, i discovered that i had to do all four at the same time, including the Tweeters to the Front speakers,
So do the back ones aswell and ur problem should be fixed
02AleroEco is offline   Reply With Quote
