Old 05-16-2008, 04:43 PM   #1
super white alero1
Trying to get it together
super white alero1's Avatar
Offset
Does anyone have rims with a +37 offset and 18"x8"? How much does it stick out from the fenders?
I found a set of Meister S2R rims but the offset is not +45. However it will clear the brembo caliper without with no need for spacer or needing to change the studs.
I don't wish to be stuck with a set of rim if it sticks out too much.
Old 05-16-2008, 07:57 PM   #2
mfuller
I used to have 17x8" wheels with a +35 offset (225/45R17 tires) and the outer edge was basically flush with the fender.......so those should fit fine.
Old 05-16-2008, 09:11 PM   #3
super white alero1
thanks the other choice was 18x8.5 with a +25 offset.
