Old 05-19-2008, 10:30 AM   #1
dbailey
dbailey is an unknown quantity at this point
Question Growling type of noise????
I have all of a sudden starting getting this growling type of noise from the area around the water pump/power steering pump. I put new radiator hoses on and properly bled the system so I don't know if coincidently the noise started right after I did that or what. Anybody ever had a growling noise like a dry bearing kinda sound before and figured out what it was? Went by the dealer and they used one of those stethoscopes and said it could be either the power sterring pump or the water pump but was hard to tell since they are both on the same bracket. Wasn't ready to pay them a $78 diagnosis charge yet until I asked you guys what you thought. One friend of mine said to pour some limited slip additive in the power steering resevoir and if it was that, that the additive would shut it right up. Went to NAPA and bought some and added it but it didn't work immediately. May have to drive it around awhile to determine if that is what it is. Anybody? Thanks guys.
dbailey is offline   Reply With Quote
Old 05-19-2008, 10:38 AM   #2
dbailey
P.S. Don't hear it at idle. Only when you rev it if that helps.
Old 05-19-2008, 11:01 AM   #3
have a werewolf stuck in your flywheel?
Old 05-19-2008, 11:02 AM   #4
C_EICK
Iv'e got it, you have a small dog in your'e engine! ok maybe not, but i had to say.
Old 05-19-2008, 12:29 PM   #5
jackal2000
jackal2000's Avatar
the transmission doesnt have a fly wheel. it has a flex plate.
Old 05-19-2008, 12:48 PM   #6
dbailey
Well it doesn't look like the limited slip additive worked. Hmmm.....
Old 05-19-2008, 12:55 PM   #7
jackal2000
jackal2000's Avatar
power steering usually whines when it is going bad. you can get a new water pump for like $20, not sure how much the ps pump is.
Old 05-19-2008, 01:32 PM   #8
dbailey
It's more like a grind/dry bearing sound than a whine. You can hear it when you drive and when sitting still and revving the engine. For sure is coming from the water pump/power steering pump area.
Old 05-19-2008, 08:08 PM   #9
dbailey
Water pump is bad. Pulley loose and bearing clicks a bit. Gonna get the ASC pump from Advance and hope it is a decent one. They say its new with a limited lifetime warranty. $25. Anybody know about it?
Old 05-19-2008, 08:17 PM   #10
bryan213
bryan213's Avatar
bryan213 is on a distinguished road
maybe bad bearings in water pump shaft. remove belt and pully check for play in the shaft.
bryan213 is offline   Reply With Quote
Old 05-19-2008, 08:33 PM   #11
dbailey
Yeah its bad. Pulley moves while under the tension of the belt. Fortuntately I have the 3.4 so should be easy to replace. Got 135,000 miles out that water pump so I don't guess it owed me anything.
Old 06-06-2008, 10:39 AM   #12
dbailey
Put new water pump in and that fixed it.
