05-22-2008, 04:42 PM
double roller setup
I don't think there is anybody else currently on here in an la1 buildup but i just ordered mine, sure is a sweet product......
http://wot-tech.com/shop/3100-3400-3.../prod_131.html
05-22-2008, 09:04 PM
thats kind of a high price for a timing chain, but guess if its the only option you have...
got any updates on your build?
HAS
-'01 alero "442" 3.4 v6, 8.2 taylor wires, 2 10's , WAI, 2.5" custom cat-back exhaust w/ dual super 40 mufflers and, KYB-GR2 struts. 15.701@87.69mph.
-'97 s10 4.3 v6, alpine head unit, camaro rims, 2.5" cat-back w/Edelbrock SDT, Edelbrock TES headers, HPPIII, and 8mm taylor wires. 15.505@87.42mph
http://www.cardomain.com/id/s104-banger
videos-
http://youtube.com/watch?v=YvkbtiBirVo
http://youtube.com/watch?v=WnmqBZkdmAM
05-22-2008, 09:33 PM
awesome
05-22-2008, 09:41 PM
Boost Guru
Including 2 gears with adjustable settings and a chain, $244.99 isn't bad at all. Adjustable cam gears for the Ecotec are $350 and you only get the two gears.
05-22-2008, 10:14 PM
high compression? with your SC?
AUTOBOT
05-23-2008, 12:06 AM
Looks great man. What else have done so for to the engine buildup? I want to get my project on my 3400 pretty soon. I'm just gathering data and money before i jump on. If you have any tips for me just let me know or pm me.
There is not such thing as too much power.
05-23-2008, 02:48 PM
i didnt relize that other timing chains costed so much. the ones for the 4.3 are barely half that, but it is pretty much a 350 timing chain.
HAS
videos-
05-23-2008, 04:05 PM
Well, let's just start by saying that most of the stuff that I have been doing probably isn't 100% necessary some of it is really probably overkill, but I only want to build the motor once, and that is just how I am.
Anywhoo I have had several problems getting the bottom end how I want it but as it stands for the bottom end it is
3400 block with .020 overbore
3500 crank reground to rod specs with radiused ends
custom radiused rod bearings
TCE External Crank Trigger
TCE double roller timing chain
800 hp scat SBC rods (ground to fit)
ARP main studs
custom comp cam
solid lifter conversion
various dry sump parts
upper end will get fully massaged too, the goal is to get the car running NA by the early part of next summer and work the kinks out before I apply the boost
not high compression well at least not until boost is applied, high output is the reason for this particular part....
05-25-2008, 02:03 AM
what does the radiused crank ends do for you? and what is an external crank trigger?
HAS
videos-
05-25-2008, 11:37 AM
when I ground down the crank, I had both sides where the rod would fit radiused, It gives it more strength. Usually how the v8s are when you would be building them up. External Crank Trigger - http://wot-tech.com/shop/3400/extern...r/prod_42.html
Basically I went to the 3500 crank because it is a forged steel crank, the 3400 crank is not and I bent the crank in my last motor. The 3500 crank has i believe a 52 tooth wheel and our crank is a 7 tooth wheel so you bolt on the ECT so you can use the 3500 crank or for a full 3500 swap....
05-26-2008, 10:49 PM
i see. thank you.
HAS
videos-
