OK, long story short, I ran over a plastic bag. Shit got caught underneath and melted onto my exhaust pipe. Shit reeks, what do I do? Do I just take a hose to it? Since, I don't have a hose and have to go to a car wash, how long should I wait until the car cools to go at it? Or is there a better solution? Littering isn't cool.
build it to break it, if it breaks it was not built well enuff ! =OFF ALL NARCOTICS ADDICTION FREE PAIN MANAGEMENT FTMFW ."million of years ago the continents were connected...." THATS FUNNY THE EARTH IS ONLY ABOUT 6000 YEARS OLD AND THEY STILL ARE CONNECTED JACK*@# !!! click here www.chronicpainanonymous.org
just let it run and burn the rest of it off (it's faster). I had that shit happen to me with my ride-on lawn mower at work. the plastic does stink, but eventually it will burn off and just be gone. then you can use steel wool or a steel brush to work off the stain.
Originally Posted by black
Worse is when the bag gets stuck on your brake rotors...
Its not a big deal on the exhaust though
