Old 05-15-2004, 12:01 PM   #1
bigd6983
as soon as the head unit gets power going to the amps the subs before any music is played give a really hard thump, its not long, just one huge thump. Is it due to a bad ground on the amplifier, bad turn on lead, is the amplifier just bad?? or could it be rca cables going into the amp, the amp wasnt installed by me and I was just wondering what the problem could be first without me having to pull the drivers seat out. Any help is appreciated, thanks.
Old 05-15-2004, 12:16 PM   #2
ccloritz
I ahd this problem with my sub after I had a line level convertor with the stock HU then went to an alpine. Circuit City installed everythign for me and then I went back the next day becasue of that and the guy had to redo a wire behind the headunit, I'm not sure which one maybe the remote turn on?
Old 05-15-2004, 12:29 PM   #3
alerosport.com
I thought this was normal? My brothers does this, always has. mine don't thump tho
Old 05-15-2004, 01:01 PM   #4
bigd6983
nah it aint normal, this is in a friends car and my car does not do this at all.....ccloritz he did have a line level that was being run off of his rear speakers to the subwoofers......its freakin loud, you will feel the thump 10 feet away.....ill check the back of the head unit when i get a chance.......thanks
any other suggestions?
Old 05-15-2004, 01:05 PM   #5
ptrudel
Designated Drunk
all 4-5 brands of subs/amps and decks (different combinations too) have always done this...it's not as bad as u describe it tho...mine really goes nuts when my cell phone is about to ring...
I'm baaaackk
Old 05-15-2004, 06:13 PM   #6
BLK03GXS
BLK03GXS's Avatar
Some amps and decks dont have a remote power on delay.. thats why your getting the problem you have...
maybe if you used a relay to remote turn on the amp it could solve it... but i doubt it...
Allso make sure that whoever installed it didnt use the ant remote led... have to use the remote led...
Old 05-15-2004, 10:29 PM   #7
sound_xtreme
sound_xtreme's Avatar
yea, ALL amps(that dont have a soft turn on feature, which most name brands do have it) will do this when the gains are turned up.
Cardomain
Old 05-16-2004, 12:08 AM   #8
Steve03TropicTeal
I have had 3 cars with 3 different subs and 3 different amps, and i have neer had turn on or turn off thump.
I would just make sure all your connections on the amp is good...
What size/kind of wiring are you using? Good stuff? Are your RCA's ran next to your power?
Old 05-16-2004, 12:16 AM   #9
AleroHawk
AleroHawk's Avatar
AleroHawk is an unknown quantity at this point
Send a message via AIM to AleroHawk
You have to look at the specs of the amp. If it has mute turn on/off cicuitry (also known as soft turn on/off as sound_xtreme said) it won't thump when the HU is turned on/off. But if it doesn't have it you will definately hear the thump.
~Justin~
J-ville, FL
"If at first you don't succeed, cheat."
AleroHawk is offline   Reply With Quote
Old 05-16-2004, 04:01 AM   #10
bigd6983
thanks guys for the help, the person who hooked up the first amp hooked it up a +12 volt source, so as soon as the key turned, so did the amp......Fixed that crap.....i tell you what......this dudes got alpine type r speakers all the way around, with the 12 type r's in the back run off all alpine amps........it plays so loud and clean, makes me want to upgrade mine lol......I definately will be getting 12's and most likely those alpines are a possibility, they sound awesome
Old 05-18-2004, 02:28 PM   #11
xsavyor1
xsavyor1 is an unknown quantity at this point
sometimes you will get a ground loop noise witch will give you that pop. Try making your ground line shorter. or longer it sometimes helps.
TEAM PRODIGY-TEAM CROSSFIRE-TEAM XS POWER
WWW.TEAMPRODIGY.NET
WWW.CROSSFIRECARAUDIO.COM
2010 BASS RACE WORLD CHAMPION 140.0DB - 149.9DB
2009 Bass Race World Champion 140.0-149.9db Class
xsavyor1 is offline   Reply With Quote
