Old 06-06-2008, 12:02 AM   #1
SittinOnChrome
SittinOnChrome's Avatar
SittinOnChrome is on a distinguished road
Send a message via AIM to SittinOnChrome Send a message via Yahoo to SittinOnChrome
$$$$ Gas saving Tips $$$$
Thirty Gas Saving Tips
The surest way you can improve your fuel cost problem is to change your motoring habits. Listed below under four categories are 30 effective methods of doing so... no need to buy expensive add-on equipment.
ENGINE WARM-UP
1. Avoid prolonged warming up of engine, even on cold mornings - 30 to 45 seconds is plenty of time.
2. Be sure the automatic choke is disengaged after engine warm up... chokes often get stuck, resulting in bad gas/air mixture.
3. Don't start and stop engine needlessly. Idling your engine for one minute consumes the gas amount equivalent to when you start the engine.
4. Avoid "reving" the engine, especially just before you switch the engine off; this wastes fuel needlessly and washes oil down from the inside cylinder walls, owing to loss of oil pressure.
5. Eliminate jack-rabbit starts. Accelerate slowly when starting from dead stop. Don't push pedal down more than 1/4 of the total foot travel. This allows carburetor to function at peak efficiency.
HOW TO BUY GASOLINE
6. Buy gasoline during coolest time of day - early morning or late evening is best. During these times gasoline is densest. Keep in mind - gas pumps measure volumes of gasoline, not densities of fuel concentration. You are charged according to "volume of measurement".
7. Choose type and brand of gasoline carefully. Certain brands provide you with greater economy because of better quality. Use the brands which "seem" most beneficial.
8. Avoid filling gas tank to top. Overfilling results in sloshing over and out of tank. Never fill gas tank past the first "click" of fuel nozzle, if nozzle is automatic.
HOW TO DRIVE ECONOMICALLY
9. Exceeding 40 mph forces your auto to overcome tremendous wind resistance.
10. Never exceed legal speed limit. Primarily they are set for your traveling safety, however better gas efficiency also occurs. Traveling at 55 mph give you up to 21% better mileage when compared to former legal speed limits of 65 mph and 70 mph.
Buy Now
11. Traveling at fast rates in low gears can consume up to 45% more fuel than is needed.
12. Manual shift driven cars allow you to change to highest gear as soon as possible, thereby letting you save gas if you "nurse it along". However, if you cause the engine to "bog down", premature wearing of engine parts occurs.
13. Keep windows closed when traveling at highway speeds. Open windows cause air drag, reducing your mileage by 10%.
14. Drive steadily. Slowing down or speeding up wastes fuel. Also avoid tailgating - the driver in front of you is unpredictable. Not only is it unsafe, but if affects your economy, if he slows down unexpectedly.
15.Think ahead when approaching hills. If you accelerate, do it before you reach the hill, not while you're on it.
GENERAL ADVICE
16. Do not rest left foot on floor board pedals while driving. The slightest pressure puts "mechanical drag" on components, wearing them down prematurely. This "dragging" also demands additional fuel usage.
17. Avoid rough roads whenever possible, because dirt or gravel rob you of up to 30% of your gas mileage.
18. Use alternate roads when safer, shorter, straighter. Compare traveling distance differences - remember that corners, curves and lane jumping requires extra gas. The shortest distance between two points is always straight.
19. Stoplights are usually timed for your motoring advantage. By traveling steadily at the legal speed limit you boost your chances of having the "green light" all the way.
20. Automatic transmissions should be allowed to cool down when your car is idling at a standstill, e.g. railroad crossings, long traffic lights, etc. Place gear into neutral position. This reduces transmission strain and allows transmission to cool.
21. Park car so that you can later begin to travel in forward gear; avoid reverse gear maneuvers to save gas.
22. Regular tune-ups ensure best economy; check owner's manual for recommended maintenance intervals. Special attention should be given to maintaining clean air filters... diminished air flow increases gas waste.
23. Inspect suspension and chassis parts for occasional misalignment. Bent wheels, axles, bad shocks, broken springs, etc. create engine drag and are unsafe at high traveling speeds.
24. Remove snow tires during good weather seasons; traveling on deep tire tread really robs fuel!
25. Inflate all tires to maximum limit. Each tire should be periodically spun, balanced and checked for out-of-round. When shopping for new tires, get large diameter tires for rear wheels. Radial designs are the recognized fuel-savers; check manufacturer's specifications for maximum tire pressures.
26. Remove vinyl tops - they cause air drag. Rough surfaces disturb otherwise smooth air flow around a car's body. Bear in mind when buying new cars that a fancy sun roof helps disturb smooth air flow (and mileage).
27. Auto air conditioners can reduce fuel economy by 10% to 20%. Heater fan, power windows and seats increase engine load; the more load on your engine, the less miles per gallon.
28. Remove excess weight from trunk or inside of car - extra tires, back seats, unnecessary heavy parts. Extra weight reduces mileage, especially when driving up inclines.
29. Car pools reduce travel monotony and gas expense - all riders chip in to help you buy. Conversation helps to keep the driver alert. Pooling also reduces traffic congestion, gives the driver easier maneuverability and greater "steady speed" economy. For best results, distribute passenger weight evenly throughout car.
30. During cold weather watch for icicles frozen to car frame. Up to 100 lbs. can be quickly accumulated! Unremoved snow and ice cause tremendous wind resistance. Warm water thrown on (or hosed on) will eliminate it fast.
EXTRA TIPS
Install pressure regulator valve (sold in auto parts stores)... Use graphite motor oil... Beware of oil additives, regardless of advertising claims... Add Marvel Mystery Oil into gas fill-ups... Investigate fuel/water injection methods and products... combine short errands into one trip... Use special gas additives to prevent winter freezing of gas lines... convert your V8 engine over to a V4 - no special kits needed!!!
SittinOnChrome is offline   Reply With Quote
Old 06-06-2008, 08:21 AM   #2
wow.. quite dated information..
Old 06-06-2008, 10:18 AM   #3
AGT
AGT's Avatar
^^ Pay attention to the man. He wants you to make sure your
Carburetor
is working right haha
Old 06-06-2008, 10:29 AM   #4
FrankTheTank
FrankTheTank's Avatar
FrankTheTank is an unknown quantity at this point
Carburetor
some people do own vehicles with carbs...my truck included.
FrankTheTank is offline   Reply With Quote
Old 06-06-2008, 10:32 AM   #5
super white alero1
Trying to get it together
super white alero1's Avatar
Question
Do you mean don't rest the left foot on the brake pedal?
Old 06-06-2008, 10:30 PM   #6
TheEdgeofSanity
TheEdgeofSanity's Avatar
i thought its bad to put your car in neutral alot because some parts aren't being lubricated while in neutral?
also, isn't it bad to pour hot water on frozen things?
2000 Chevrolet Malibu LS
Old 06-06-2008, 11:24 PM   #7
Originally Posted by super white alero1 View Post
Question
not when this was written. the brake pedal (back then) was not only made of wood, but would push a piece of 2x4 into the rim of the tire as a method of slowing the sled down. thus.. board pedal.
Old 06-07-2008, 07:09 AM   #8
Blender345
Blender345 is on a distinguished road
^^ how old is this? I hope thats a joke lol.
duhh lol
Blender345 is offline   Reply With Quote
Old 06-07-2008, 07:24 AM   #9
CiscoPath
CiscoPath's Avatar
CiscoPath is an unknown quantity at this point
This reads like one of those out-dated movie scripts they show you in drivers ed where you have to roll to the next shop after the beep.
CiscoPath is offline   Reply With Quote
