Old 06-07-2008, 02:17 AM   #1
kniedelm9490
kniedelm9490's Avatar
kniedelm9490 is on a distinguished road
Send a message via AIM to kniedelm9490
Powr-Flo Mass Air Sensor
yes ? no?
http://truck.hownd.com/product-2097-...ir-sensor.html
kniedelm9490 is offline   Reply With Quote
Old 06-07-2008, 04:21 AM   #2
Save your money
Old 06-07-2008, 11:13 AM   #3
The flow bench tested design of the JET Mass Air Sensor provides airflow increases of up to 45% and installs in 10 minutes or less.
45% ?? wow, I guess that was versus having a wet sock stuck in the maf screen before?
Old 06-07-2008, 11:17 AM   #4
if it sounds like a GREAT improvement, w/ minimal work. its a lie.
and that just looks like a MAF w/o a screen, and a circuitboard stuck in the middle. i can't believe people buy this crap.
Old 06-07-2008, 11:38 AM   #5
super white alero1
Trying to get it together
super white alero1's Avatar
Unless you got as modified intake system (intake tube, manifold, port matching, a bigger TB) you won't see a difference in air flow. The engine only draws in so much air due to system restriction and volume of cylinder. It won't increase performance, but if it anything like a resistor then it might fool the computer into thinking its drawing more air and the computer will compensate by adding more fuel, so you might think its more powerful, but you are actually losing performace and gas mileage
Old 06-07-2008, 09:39 PM   #6
kniedelm9490
haha i have a ghetto rigged shortram intake we put togather out of spare parts its held up pretty well so far
Old 06-08-2008, 01:11 AM   #7
Originally Posted by kniedelm9490 View Post
Simple answer, with your level of build so far.....no. It will give you no noticeable increase in performance other than "placebo effect" (you think you feel the power increase because you think you're supposed to).
