Old 06-07-2008, 07:26 PM   #1
alerocar01
alerocar01's Avatar
alerocar01 is an unknown quantity at this point
Projector Project
Ok i know there are a lot of threads on this but this would help me get the answers a lot faster. Anyways i want to put projectors in my car and was wonder what is the best headlights to get to harvest the projectors from. i would like to get some for cheap and have them go in fairly easy. Also for the people that have done this, how hard is it to do. I would say i am a little handy but if its something that is out of my league, probably don't want to try it. Is this something that i could knock out in a day or weekend? Thanks for the help!
DO WORK
alerocar01 is offline   Reply With Quote
Old 06-07-2008, 08:57 PM   #2
CiscoPath
CiscoPath's Avatar
CiscoPath is an unknown quantity at this point
I don't think a definitive choice has been made yet. Two or three folks here actually had them, but i'm not sure if a shop retrofitted them or if they were home made. I tried it with the buggy eye headlights from an older Acura Integra, but ya have to butcher the assembly to get it in there. I've heard the best ones are the Germans: BMW, Audi, etc.
CiscoPath is offline   Reply With Quote
Old 06-07-2008, 09:31 PM   #3
super white alero1
Trying to get it together
super white alero1's Avatar
any bimmer would work. The best projector are probably out of a TSX. I tried Lexus but they are too long.
Old 06-07-2008, 10:11 PM   #4
mercury cougar
or any BMW
Old 06-07-2008, 10:26 PM   #5
CiscoPath
CiscoPath's Avatar
Guess I'll be making a trip to the salvage yard
Old 06-07-2008, 10:27 PM   #6
CiscoPath
CiscoPath's Avatar
So were the Teggys
Old 06-08-2008, 01:02 PM   #7
alerocar01
alerocar01's Avatar
also think i might need to get a second set of headlights. hopefully i can find some for cheap. not may aleros in salvage yards around here. if anyone has some for cheap, shoot me a pm.
DO WORK
Old 06-08-2008, 01:41 PM   #8
Spilner521
Boost Guru
Spilner521's Avatar
The projectors with best beam patterns are from a Honda S2000 or Acura TSX. It's not an easy project and it's very time consuming, especially if you get easily distracted like me
I used TSX projectors in mine with Infiniti G35 ballasts and Phillips 4300K HID bulbs. I modified them a little to get more of the nice blue cutoff. I just need to make a shroud so that only the projector lens shows through and the rest of the projector body is covered.
Old 06-08-2008, 01:59 PM   #9
I like your projectors, Spilner. However, you do need to fabricate something to go around the projector housing to hide the mount and make it look more clean and that it actually belongs there. lol
Old 06-08-2008, 03:02 PM   #10
Spilner521
Boost Guru
Spilner521's Avatar
Yeah thanks I said that's what I needed to do. I would never put them on the car like that without the projector body being covered. I already have some plastic cut out to fit around the projector, I just need to fit it into the low beam housing and glue it in and then paint everything to match.
Old 06-08-2008, 03:20 PM   #11
CiscoPath
CiscoPath's Avatar
bangin job, Spilner. You actually found TSX assembies at a salvage yard?
Old 06-08-2008, 04:09 PM   #12
-Alero-
-Alero-'s Avatar
izn tribl
AUTOBOT
Old 06-08-2008, 04:21 PM   #13
holy crap spil! i didn't know you were doing that. makes me want to now. what local junkyard did you find a tsx at?
Edit: ebay huh.... hmm... now you got me thinking....
Old 06-08-2008, 05:00 PM   #14
Spilner521
Boost Guru
Spilner521's Avatar
Nope, eBay.
Old 06-08-2008, 07:20 PM   #16
Spilner521
Boost Guru
Spilner521's Avatar
Yep. I didn't get just the projectors, I got the whole headlight assemblies and had to tear them apart to get the projectors out. I also bought the G35 ballasts on eBay and a set of brand new phillips 4300K bulbs.
This wasn't a whole kit, I pieced everything together. Using OEM components is way better than any aftermarket kit.
Why do you keep posting that?
Old 06-08-2008, 07:21 PM   #17
-Alero-
-Alero-'s Avatar
^^oh sorry my fault, i thought they did custom installs for projectors in any car.... my fault
AUTOBOT
Old 06-08-2008, 07:23 PM   #18
Spilner521
Boost Guru
Spilner521's Avatar
They do, but I didn't go through them for anything. These were made by me.
Old 06-08-2008, 09:17 PM   #19
-Alero-
-Alero-'s Avatar
very time consuming, what did you use to hold the projector brackets? and any pics of installed?
AUTOBOT
Old 06-10-2008, 04:23 PM   #20
Spilner521
Boost Guru
Spilner521's Avatar
Yeah they are very time consuming. I started this project in late February, and this is as far as it is, and only one headlight is this far. I haven't even pulled the other one apart yet. Then again I also haven't worked on it since probably early April. I took those pics a couple minutes before I posted them that day.
There aren't any brackets that hold it in. I had to cut out the middle of the reflector housing to fit the projector housing through. If you look at the pics you can see screws in all four corners of the projector body. All I did was drill holes for the screws in the housing, run the screws through the holes and tighten a nut down on the screw to the the whole projector in place.
No pics of them installed because I didn't install them yet. I need to cut a small circle in the frame where the headlight mounts since the bulb mount sticks further out the back of the headlight than stock.
