Old 06-07-2008, 11:52 PM   #1
cliffordwoeller
You got beat by an Alero!
cliffordwoeller's Avatar
cliffordwoeller is on a distinguished road
Send a message via AIM to cliffordwoeller Send a message via MSN to cliffordwoeller Send a message via Yahoo to cliffordwoeller
Help me clear my corners
ok sooo I have my headlights right here beside me in my bedroom so I can "clear my Corners" my question is do i take all the hardware off of irt basically take off what I can or tha can be taken off and then i wanna try the oven method but am a lil scared I will burn something or mess one of the light housing units up plus theres wires in side it any help ?
cliffordwoeller is offline   Reply With Quote
Old 06-08-2008, 12:02 AM   #2
CiscoPath
CiscoPath's Avatar
CiscoPath is an unknown quantity at this point
Uh........an oven is not necessary. Some use a hair dryer but all you really have to do is locate the little clips that attach the lens to the assembly and pry them. If you break them, no biggie because the serve no real purpose. The sealant is what holds the lens on. I recommend, after prying the clips, getting a butter knife and wedging it between the lens and assembly. When it doesn't dig anymore, pry it loose enough to fit your fingers inside. With your fingers in, just slowly pull it apart. It'll be tough in the beginning, but the further you go down, the less resistance you'll have.
CiscoPath is offline   Reply With Quote
Old 06-08-2008, 12:08 AM   #3
CiscoPath
CiscoPath's Avatar
The orange reflector just snaps out. Don't be afraid to break it, you're not putting it back. Once out, wipe off the chrome-like part to avoid fingerprints. If ya just want to put it back together at that point, just snugly refit the lens back to the assembly. The correct way, though, is to apply a bead of fresh caulk. Without it, dirt/dust will get inside. The hair dryer may make it easier. It's up to you
Old 06-08-2008, 12:13 AM   #4
cliffordwoeller
ok thanks cisco i appreciate it
Old 06-08-2008, 12:40 AM   #5
cliffordwoeller
i cant get the chrome away from the lens why is that ?
Old 06-08-2008, 01:10 AM   #6
greenbastard
greenbastard's Avatar
greenbastard is an unknown quantity at this point
its plastic welded together. i used a steak knife to cut it but dont break them. after looking for a half an hour i found the thread.http://www.aleromod.com/forums/showt...=clear+corners. i put my head light assembally in the freezer then chiped all the silicon off. when you put it back together fill the grove in the rear assembly all the way around with silicon, then the chrome bezle, and final drop the cover over and let it set.
01 Alero GX 3400 swapped
v8 swapped 84 s10
greenbastard is offline   Reply With Quote
Old 06-08-2008, 02:57 AM   #7
CiscoPath
CiscoPath's Avatar
forgot about that thing being stuck to it. It's been 8 years since I did it, sue me..lol
