Old 06-28-2008, 07:27 PM   #1
dtldiaspora
dtldiaspora's Avatar
dtldiaspora is on a distinguished road
Question i need info!
anyone know the where i can find the torque specs for the engine, so that when i put everything back on its not to loose or to tight.. just wanna make sure the rod bearing and heads and all the other things that need to be torqued are properly tightened down
dtldiaspora is offline   Reply With Quote
Old 06-28-2008, 07:35 PM   #2
Yeah, try the Haynes manual. Talk to Cliff8928 to have him send you the Overhaul Procedure Manual which tells you exactly how to uninstall/reinstall everything and what torque specification to use.
Old 06-29-2008, 01:39 AM   #3
dtldiaspora
i just found a link tonight about it on 60 degrees, appears to be everything i need but ill find out later i suppose, but if anyone else needs it for the 2.2 or 2.4 they had the link to those engines also
http://60degreev6.com/content/3400_E...Specifications
