Old 06-29-2008, 02:23 PM   #1
CaRcRaZy
CaRcRaZy's Avatar
CaRcRaZy is on a distinguished road
taillights not brightening
i have a 2000 alero coupe. all my break lights are on but when i push on the break they do not brighten. Does anyone have any idea why this might be?
CaRcRaZy is offline   Reply With Quote
Old 06-29-2008, 02:27 PM   #2
check your wiring/fuses. if the bulbs have 2 filaments one, might be burned out.... (not sure if our cars have that or not)
Old 06-29-2008, 02:55 PM   #3
Vinalero
Vinalero's Avatar
I think theres a fuse specifically for the brake lightning. Check in both drivers and passengers fuse panel and dont forget the one under the hood, beside the brake fluid tank.
You could also check in your user manual, if you still have it, where is the concerned fuse.
Old 06-29-2008, 03:21 PM   #4
Originally Posted by CaRcRaZy View Post
break
brake
If ALL of your brake lights light up idling, and ALL of them do not light up brighter when the brake is applied, I doubt every single bulb's second filament burned out. Most likely some other sort of wiring issue, likely a fuse.
Old 06-29-2008, 04:37 PM   #5
bryan213
bryan213's Avatar
bryan213 is on a distinguished road
break light switch.. all data will help u with that
bryan213 is offline   Reply With Quote
Old 06-29-2008, 11:17 PM   #6
Does the 3rd light work at all?
Old 07-02-2008, 11:37 AM   #7
super white alero1
Trying to get it together
super white alero1's Avatar
check your fuses and relay. Brake switch is not the cause. If your brake switch failed you cannot switch out of park.
MODS:???
Old 07-02-2008, 01:05 PM   #8
AGT
AGT's Avatar
Unless you accidentally replaced the bulbs with single filament type, then you are looking at the fuse panel hopefully
