Old 07-01-2008, 03:37 PM   #1
the_don_rolo
the_don_rolo's Avatar
the_don_rolo is on a distinguished road
Transmission Fluid Fill
I let go of some tranny fluid by accident, about a quart, and i dont know how to re-fill it, can someone tell me how? I know theres a check plug on the side of the tranny, and i bought fluid, i dont even know if its driveable right now to take the to a dealership? Can anyone tell me what to do?
the_don_rolo is offline   Reply With Quote
Old 07-01-2008, 03:46 PM   #2
There's a cap in the engine bay to the right of the engine.
Old 07-01-2008, 04:22 PM   #3
cliffordwoeller
You got beat by an Alero!
cliffordwoeller's Avatar
cliffordwoeller is on a distinguished road
Send a message via AIM to cliffordwoeller Send a message via MSN to cliffordwoeller Send a message via Yahoo to cliffordwoeller
can you do your own flush ? if so how do you do it. and if not how much will it cost to have a shop do it?
cliffordwoeller is offline   Reply With Quote
Old 07-02-2008, 01:16 AM   #4
Is it an Automatic?
Old 07-02-2008, 01:44 AM   #5
How do you know you lost only a quart
Old 07-02-2008, 10:12 AM   #6
super white alero1
Trying to get it together
super white alero1's Avatar
A quick search will reveal wonders for you young grasshopper.
MODS:???
Old 09-24-2008, 09:25 PM   #7
leoalero
leoalero's Avatar
leoalero is on a distinguished road
Send a message via MSN to leoalero
if its 5spd tranny theres a red cap clearly on the to of the transmission get this off by turning and fill it full as you see the fluid!!Then its finish if you wanna drain it before and fill brand new oil get under the car check on the tranny and youll see a drain plug,get the plug off by turning it and wait till theres no oil left,then do the same thing described on the top the end the job check for fluid link before running the car!!
For the automatic one,start the engine(the engine must be running at idle to check the fluid level well)check on the left side of the engine,youll see a yellow or black stick,pull it then fill it with new automatic transmission fluid fill the oil till you reach the maximum point on the gauge!!Now youre good to go!!
leoalero is offline   Reply With Quote
Old 09-24-2008, 09:32 PM   #8
undecided02
undecided02's Avatar
undecided02 is on a distinguished road
Hope u got small hands cause its a bit of a squeeze to reach the cap.
undecided02 is offline   Reply With Quote
Old 09-24-2008, 11:08 PM   #9
^^ Yes but if you put an intake on the car, no problem
If it's a 5 speed, you really shouldn't be changing tranny fliud at all
Old 09-24-2008, 11:11 PM   #10
CactusWill
Shouldn't as in you don't need to? Or shouldn't as in it would be bad to change the fluid? jw
Old 09-24-2008, 11:35 PM   #11
Typically tranny fliud in a manual is more like a lube and less like an oil like in auto trannies
Old 09-25-2008, 12:25 AM   #12
CactusWill
word. good lookin out
Old 09-25-2008, 01:06 PM   #13
freakout
freakout's Avatar
freakout is an unknown quantity at this point
A manaul tranny still needs to have it's lubricating oil changed. There is a recomended interval, no idea what it is. The oil will break down and pick up contamination.
freakout is offline   Reply With Quote
