Old 07-04-2008, 09:41 PM   #1
kniedelm9490
kniedelm9490's Avatar
kniedelm9490 is on a distinguished road
Send a message via AIM to kniedelm9490
Problems with the Ho
1. when in park the engine is idling really weird. I'm not sure if its the the belt or something else. but it sounds really bad to me but no one else seems to notice it
2. when i got on the highway to match the traffic i put the pedal to the floor and at about 50 there was a high pitch sound (kinda like a squeek) i think it might be the belt, even though it was replaced the last year.
3. my intake isn't sucking like it used to. pulled it out checked the sensors with a volt meter everything seemed fine. but the filter isn't sucking like when i first put it in and doesn't sound the same. (maybe i've just gotten used to the change of sound) i remember when we first put it in it sounded amazing
if "cliff is reading this" i might make it a goal to head out to auto zone where u work next weekend when i get paid and get your opinion on it
but any suggestions are welcome thanks guys. I'm sure u guys are out and about on 4th of july but ill check in later tonight and tommarow morning thanks!
kniedelm9490 is offline   Reply With Quote
Old 07-04-2008, 10:07 PM   #2
1. You're going to have to clarify. What's the tachometer do? Is it a squeak? A rattle? A grinding noise? ONLY in park?
2. Could be the belt, or tensioner, go pull on your serpentine belt and see how tight it is. If you can pull it a good 1.5-2 inches it's too loose.
3. maybe now that it has some mileage on it it doesn't filter as well, less resistance, less "sucking" noise, better performance.
Old 07-04-2008, 11:06 PM   #3
kniedelm9490
tachometer is reading normal it kinda sounds like a grinding. when i put it in gear i really don't hear much the sound stops
ill check the belt in morning and let you know
Old 07-04-2008, 11:30 PM   #4
blueolds01
blueolds01's Avatar
blueolds01 is on a distinguished road
Send a message via AIM to blueolds01
i've run into an alternator making a mad sqeaking noise before.
HAS
-'01 alero "442"
3.4 v6, 8.2 taylor wires, 2 10's , WAI, 2.5" custom cat-back exhaust w/ dual super 40 mufflers and, KYB-GR2 struts. 15.701@87.69mph.
-'97 s10 4.3 v6, alpine head unit, camaro rims, 2.5" cat-back w/Edelbrock SDT, Edelbrock TES headers, HPPIII, and 8mm taylor wires. 15.505@87.42mph
http://www.cardomain.com/id/s104-banger
videos-
http://youtube.com/watch?v=YvkbtiBirVo
http://youtube.com/watch?v=WnmqBZkdmAM
blueolds01 is offline   Reply With Quote
Old 07-16-2008, 01:07 AM   #5
bryan213
bryan213's Avatar
bryan213 is on a distinguished road
screw driver to the ear works lol
bryan213 is offline   Reply With Quote
Old 07-16-2008, 01:08 AM   #6
Kilroy
Kilroy's Avatar
Kilroy is on a distinguished road
In more ways than one!!
Kilroy is offline   Reply With Quote
Old 07-16-2008, 01:02 PM   #7
TheEdgeofSanity
TheEdgeofSanity's Avatar
is it like a metallic grinding where its somewhat high pitched? because if so i am having the same problem and suspect its my dying transmission or an idler pulley.
2000 Chevrolet Malibu LS
Old 07-16-2008, 05:09 PM   #8
kniedelm9490
ya its a metallic kinda grinding ... i wish it would just die already lol so i could get the problem fixed. along with the dead ac compressor
