07-14-2008, 01:10 AM
V.I.P baby
sun roof
i wanna get a sunroof what is a good brand and how much should it cost me
07-14-2008, 01:18 AM
just cut the roof of an oldsmobile with a sunroof and weld it on ur car.. i've always wanted to see someone do it, technically it is possible, my 3.4 is all wired for a sunroof, just a lil bit of work and painting.. have a stock one (less chance of leaking)
or u could just get one of those stick on sunroofs
(off topic) anyone with a sunroof.. u ever have leak problems
07-14-2008, 01:30 AM
i was reading about this a while back... not a good idea.. it will leak regardless.... after market sunroofs blow
V.I.P baby
i would have to leave it to the pros i would fork it up then it would leak
07-14-2008, 01:32 AM
V.I.P baby
damn i really want one
07-14-2008, 01:42 AM
what if u cut half way into the a-pillar, and the quarter panel? shouldnt leak then, that was my original idea, just didnt have the details in the 1st post
07-14-2008, 02:05 AM
Ziebart in Jamestown will do them. I got a friend who works there and he said depending on style they would probably be like $400 installed starting out (more than likely not electric). Go down there and check it out.
07-14-2008, 02:35 AM
V.I.P baby
thanks
07-14-2008, 09:15 AM
Trying To Help
i put and aftermarket in a fullsize truck and it never leaked but for the life of me can't remember what company it was from i bought it at a yardsale
03 OLDS ALERO
07-14-2008, 09:50 AM
If you want an Alero with a sunroof, sell what you've got and go buy an alero with a sunroof. Nearly ever aftermarket sunroof ever installed has had leak problems it seems like. Horror stories abound when you look into it. As for my factory sunroof, I did have problems with the A-pillar drain not being installed properly, or something to that effect. I had major leak problems just after I bought the car. Water would leak into the fuse panel on the drivers side of the dash causing shorts and blown fuses. Many trips to the dealer and they finally fixed it. I think there may have been a TSB somewhere along the line for it.
07-14-2008, 11:53 AM
am i mistaken.. i thoguht only the 2.4 had a sunroof option, not the 3.4.. i have a 3.4 and want a sunroof
07-14-2008, 12:35 PM
Sure the 3.4 had a sunroof option.. I have a GLS (which comes with a sunroof) which has the 3.4.. never really had any problems with my sunroof and im using it almost everytime i get into the car.
07-14-2008, 03:09 PM
Best option is like what someone said here: You would need to chop the top of an Alero with an electric sunroof and weld it to your car. Its very pricey though.
07-14-2008, 03:25 PM
ragtop ftw
07-14-2008, 06:46 PM
V.I.P baby
I was talking with bizarre about that and I think it would be sweet. If anyone can find a pic or photo shop one that would be sweet!
07-14-2008, 09:31 PM
Beautiful car. I think we all know whos car that is... If not, get with the program.
I am planning on doing this, just looking for a cheap price.
07-14-2008, 09:44 PM
As funny as the sticker is, the questions from potential buyers are hilarious:
"So what type of motor does it take and how do i go by wiring it all up and locating the switch??"
"Will I have to declare the addition of this modification to my insurance company and will it compromise the structural integrity of my car?"
"Will this work with my convertible?"
"How much horsepower does this add?"
07-14-2008, 09:48 PM
^That is one of the funniest pictures I have ever seen in my life. Ion, can you add that to the aleromod upgrades page?
07-14-2008, 09:51 PM
hmm I should
07-14-2008, 10:05 PM
MINIac
My MINI came with a really nice panoramic double sunroof. Get a new car.
