Old 07-16-2008, 02:28 PM   #1
Vinalero
Vinalero's Avatar
Car resetting ?
Anybody had their car "reset" at start up?
Let me explain this: yesterday I get in the car as usual after work and start the car as usual. However, at start up, the needles go all the way to max (7000 rpm, 240 km/h, Full gas, Overheating) and goes back downs just like when you unplug or plug back the cluster. Also, my trip mileage was reset that way.
Anyone ever experience that?
By the way, my aftermarket radio wasnt reset that way.
Old 07-16-2008, 02:32 PM   #2
TheEdgeofSanity
TheEdgeofSanity's Avatar
i think ur battery might be going bad. that happens when the voltage gets too low. is it cranking hard?
2000 Chevrolet Malibu LS
Old 07-16-2008, 02:57 PM   #3
JOEY GLADSTONE
JOEY GLADSTONE is on a distinguished road
my friends GA used to do that, i was like wTF is that
JOEY GLADSTONE is offline   Reply With Quote
Old 07-16-2008, 03:42 PM   #4
TheEdgeofSanity
the grand am's are supposed to do that. its something about ponitacs where they call it a gauge sweep.
alero's aren't programed to do that.
i'm convinced its a voltage problem. take it to murray's or autozone and have your battery and alternator tested.
Old 07-16-2008, 05:04 PM   #5
01silveralero
01silveralero's Avatar
its ur alternator going
Goal - Mid 11s all motor.
Old 07-16-2008, 05:57 PM   #6
Vinalero
Vinalero's Avatar
I might tend on the battery side because the stock alt went out on the last owner who replaced it like 2 years ago with a stronger alternator. I really hope its not the alt, because I dont really feel like getting the supercharger out and in AGAIN
I'll check the battery or maybe something is loose from when I tighted the connection back when installing my supercharger. That may sound noobish as hell, but could I check the battery with my voltmeter putting both wires on both battery poles or is it better to use like the wire from the cubby hole?
By the way, the car is cranking hard and I have no light dimming at night and I have 2 amps.
Old 07-16-2008, 06:36 PM   #7
2 amps as in stereo amps or in your battery? if its in your battery its definately bad and if you mean for the stereo that would be why your alt. would be going out so soon again.
Old 07-16-2008, 07:06 PM   #8
Vinalero
Vinalero's Avatar
lol its 2 amplificator for speakers. I have one like 100 W for speakers in the car and one 600 w peak for my sub, but my sub is out of my car for more than half a year
I do not drain enough currrent to screw my alt that soon.
Old 07-16-2008, 07:52 PM   #9
Most likely the bat at least it was when mine did it.
Old 07-16-2008, 08:09 PM   #10
Midgear
on vacation
My car has done that while i was going down the road.. followed by a series of lurches like the fuel was cutting off and on.. it hasnt done the lurch thing in about 3 months though-
WILL NEVER FORGET
Old 04-07-2009, 12:01 PM   #11
ndottaylor
ndottaylor's Avatar
ndottaylor is on a distinguished road
Send a message via AIM to ndottaylor Send a message via MSN to ndottaylor
Mine's actually doing the same thing right now. And its definately having hard starts... no bueno at all!!
ndottaylor is offline   Reply With Quote
Old 04-07-2009, 12:20 PM   #12
Battery.
