Old 07-16-2008, 06:13 PM   #1
dtldiaspora
dtldiaspora's Avatar
dtldiaspora is on a distinguished road
if it ain't one things its another!
So while driving my car its making what seems to be a grinding noise or rubbing, whenever i turn the wheel to the right the noise will stop until i straighten the wheel back up,
the only thing that i can see that it might be is the front right rotor which has some pretty visible scraps on from where the brake pad is digging into it i guess. someone told me it might be my cv joints but i'm unsure if its them or not.
any help is appreciated!
dtldiaspora is offline   Reply With Quote
Old 07-16-2008, 06:20 PM   #2
Sounds like the wheel hub.
Any dash lights?
Old 07-16-2008, 07:19 PM   #3
dtldiaspora
i've had the normal 3 lights on ( trac off, service vechile, and forgot the other ) and never heard this noise, its a pretty loud noise at that
would the wheel hub cause my rotor to get messed up like it is?
Old 07-16-2008, 09:17 PM   #4
AftermathAlero
yep. the wheel hub bearing when they are messed up, will cause the rotor to be leaning to a side, too.
100 bucks at autozone, or any parts store. easy fix.
Old 07-16-2008, 09:40 PM   #5
dtldiaspora
so more than likely the rotor that is messed up is the wheel hub i need to replace right? or should i replace both?
Old 07-16-2008, 09:42 PM   #6
Midgear
on vacation
well- if the rotor has scratches / gouges.. I would say yes.
WILL NEVER FORGET
Old 07-16-2008, 09:52 PM   #7
dtldiaspora
ya its scratches are really noticable its the only 1 out of the 4 that are scartched up the others are pretty smooth
Old 07-16-2008, 10:12 PM   #8
bkathsalero
bkathsalero's Avatar
bkathsalero is on a distinguished road
Send a message via MSN to bkathsalero
yep ABS and tracoff are ur sign.. usually service vehical soon is a bulb out (ive noticed)
bkathsalero is offline   Reply With Quote
Old 07-16-2008, 10:18 PM   #9
dtldiaspora
well i had the lights on for awhile, but never had the screetchin or grinding noise until recently
bad thing is i just got done rebuilding my motor and now i gotta fix this! hence the title
but thats life
Old 07-16-2008, 10:41 PM   #10
Pacho
Put the front of the car on jacks, raise the car high enough to take off both front wheels. Start the car and make sure this whole time to have the emergency brake engaged. When i needed to find out if mine was the cv axle or something else this is what i did and it ended up being the passenger side cv axle, put the car in drive and turn the wheel and have someone or yourself observing the car while doing it.
Old 07-19-2008, 08:49 PM   #11
Midgear
on vacation
^^^ hell that's what I'd do.. screw blowing money at a shop to have them raise it up and charge 50 bucks just to get the car off the ground-
WILL NEVER FORGET
Old 07-20-2008, 12:09 AM   #12
dtldiaspora
i fixed it the other day, the bearing was shot in the front right side, but i still got the 3 lights so i'm assuming one of the others will soon be following.
Old 07-20-2008, 12:19 AM   #13
AftermathAlero
The light is for the ABS sensor inside the wheel bearing assembly. You could have a good bearing but the sensor inside is bad. Which means u got to change out the whole assembly.
Only way to know which one is to find a shop that has a SNAP-ON ABS code scanner. Or the GM tech2 scanner. And they can read the code to location what corner sensor is bad.
Old 07-20-2008, 11:29 AM   #14
ALERO81
ALERO81 is on a distinguished road
I agree I just replaced my wheel hub bearing well both of them best way to tell is getting it checked out
Just so you know my car made the same sounds and it was the wheel bearing not a hard job to do but I just paid a mechanic to do it for me
ALERO81 is offline   Reply With Quote
