Old 07-19-2008, 11:20 PM   #1
ALERO81
ALERO81 is on a distinguished road
Transmission fluid
I change my tranny fluid today with no problem except this there is a drip that is flowing out from the transmission pan I know what you are thinking ... just tighten the bolts right... well this is where the problem starts there tight I dont want to make them any more tighter for fear of striping the thread on the bolts ....done that before and its not fun ! I don't know if I should take the pan off again and try to reset the gasket? toward the back of the car there is a spot on the tranny pan where you would thing a bolt would go but in fact there ids no bolt for there this is where the fluid is leaking from the two bolts beside it are tight any idea on what to do ?
Just so you know I bought a transmission filter and gasket kit from a local auto part store I'm thinking it may be the gasket
ALERO81 is offline   Reply With Quote
Old 07-19-2008, 11:28 PM   #2
JOEY GLADSTONE
JOEY GLADSTONE is on a distinguished road
get a new plug screw from a local auto parts store and try that.
JOEY GLADSTONE is offline   Reply With Quote
Old 07-20-2008, 12:07 AM   #3
dtldiaspora
dtldiaspora's Avatar
dtldiaspora is on a distinguished road
i could be wrong, but to my knowledge there isnt a drain screw for the tranny
dtldiaspora is offline   Reply With Quote
Old 07-20-2008, 11:21 AM   #4
ALERO81
??? there is no drain plug to change the transmission fluid you drop the pan there is about 8-9 bolts which are about 8mm and beside that the bolts are not stripped
