Old 08-08-2008, 10:56 PM   #1
jwateland
jwateland is on a distinguished road
headlights shaking
has anyone else had a problem with thier headlights shaking when you go across bumps?
jwateland is offline   Reply With Quote
Old 08-08-2008, 11:23 PM   #2
how can you tell its headlights when the whole car is shaking?
Old 08-08-2008, 11:24 PM   #3
dragon8807
dragon8807's Avatar
dragon8807 is on a distinguished road
Send a message via Yahoo to dragon8807
mine do that when i go across the railroad tracks by school
99 alero - totalled
96 impreza 5spd awd - sold
dragon8807 is offline   Reply With Quote
Old 08-08-2008, 11:25 PM   #4
Midgear
on vacation
because when you hit a bump with a loose headlight.. the headlight is still bobbling up and down when your car isnt shaking at all.. plus you can see the light in front of the car twitching and shaking as well..
check where the headlights are mounted.. make sure they are tightly secured- also check your bulbs to make sure they havent shaken out of the sockets-
let us know how it goes.
WILL NEVER FORGET
Old 08-09-2008, 04:30 AM   #5
jwateland
yeah still not sure, it must be something with the bumper seeing how the whole thing is all mounted right along with the bumper assembly. One stupid question though: How come when you align the horizontal on the headlights, and i use the arrow and line thing in the headlights, does the headlights aren't centered and aim more towards the right?
Old 08-09-2008, 12:19 PM   #6
All headlights are supposed to do that, It's so your lights don't shine so much towards other drivers.
I need to adjust my headlights up a bit I think, I have like... No range on them.
Old 08-09-2008, 12:42 PM   #7
make sure the clip are pushed down and the head light is all the way back so the slide clips catch. this happen to me and I noticed the light shaking and almost lost it. that would suck
Old 08-09-2008, 12:46 PM   #8
Alerosaint
Gone but not forgotten
Alerosaint's Avatar
Alerosaint is on a distinguished road
Send a message via AIM to Alerosaint Send a message via Yahoo to Alerosaint
yeah make sure the headlight is in the clip good...but when mine was shaking i found out I had couple cracks in the header panel inside the clip area...so inspect that and if it is busted then order a new one
header panel
Alerosaint is offline   Reply With Quote
Old 08-09-2008, 12:51 PM   #9
Vinalero
Vinalero's Avatar
It could also be in the headlight housing also. Those of you who cleared their corner will understand : Those white pieces that adjust the lights inside the housing are attach in the housing with "little round balls" that clips in there. Its hard to explain in english for me, so if anyone know what I'm talking about, it would be appreciated.
When I bought a used headlight, it did that same thing, I found out it was this when I took the assembly appart. The "little white round thing" was unclipped.
