Old 08-15-2008, 08:48 AM   #1
ALERO81
ALERO81 is on a distinguished road
1 MORE QUESTION pcv valve
My car is still running strong but I have one more question for automotive guys
what dos the pvc valve do my line is ok but where the pvc connects to the hose its held in by a twist tie ?? and when I pulled out I don't feel air being sucked in ? is this normal.
ALERO81 is offline   Reply With Quote
Old 08-15-2008, 08:56 AM   #2
PCV = Positive Crankcase Ventilation
PVC = Polyvinyl Chloride
It vents the crankshaft case of gases that build up pressure in the engine back into the air intake to be burned off/pumped through.
It's not *that* important, but use a real hose clamp on it.
Old 08-15-2008, 09:03 AM   #3
ALERO81
Oh .... ok thank you !
