08-17-2008, 10:15 PM
what happens when u mix these
what happens when u top off u coolant that had g-5 in it with a liter of dexcool how much harm will be done?
08-17-2008, 10:17 PM
your shit dun splode.
08-17-2008, 10:20 PM
turns into a sludge if i remember right
08-17-2008, 10:28 PM
good luck getting the Jello outta there.
08-17-2008, 10:29 PM
my neighbor had a flush done and they didnt fully top it off for her and her low coolant light came on i checked res it was dry so i toped it off. now first off it says dexcool right on res second i knew cuz my car it takes dex. so we looked at her reciept they put g-5 in her damn car for sure. now im wondering am i going to ruin her car. it had to be atleat half a liter i toped with 50/50 dexcool. what the hell how could they do that. what should i do?
08-17-2008, 10:32 PM
You could put regular green stuff in your car if you did a rad flush. You just cant mix both.
08-18-2008, 02:10 AM
on vacation
Originally Posted by irondiezl3
what should i do?
you get that fluid out of the radiator ASAP and make sure to rinse it all out.. then fill it full of ONE BRAND of coolant.
WILL NEVER FORGET
08-18-2008, 02:12 AM
08-18-2008, 03:01 AM
I think you be glad it's not your car.
08-18-2008, 03:02 AM
on vacation
WILL NEVER FORGET
08-18-2008, 03:08 AM
 X2
08-18-2008, 07:33 AM
if the fluid is low and you need to "top it off" you do so with WATERRRRRRRRRRRR not another brand of coolant!
awesome
08-18-2008, 07:38 AM
What is G-5?
08-18-2008, 10:50 AM
mother f*cker u gotta be kidding me im gunna flip out on that place. who the hell puts g-5 in a alero? i heard pulling the radiator hose and hosing the system out still doesnt get it out of the block though?
08-18-2008, 10:53 AM
Try having a place flush it otherwise if that fails its tear down the engine and clean and put back together time.
Also, I have never heard of G5 coolant. Ever. A Google search indicated that the Apple G5 computer has coolant in it, but no such thing as a type of vehicle coolant named as such.
08-18-2008, 10:58 AM
very popular goes in eruopean and fords use it at valvoline its yellow.
08-18-2008, 11:09 AM
Oh, that's because it's called "G-05" not G-5 or G5.
Originally Posted by Post on GAGT.com
Don't worry if they don't get all the Dex-cool out, because Zerex G-05 is compatible to be mixed with any coolant.
(Not that you want to intentionally mix different types of coolant though.)
08-18-2008, 11:31 AM
THANKGOD the zerex is whats in her car.
08-18-2008, 01:22 PM
I'd still flush it completly and call it a day.
