Old 08-18-2008, 02:41 PM   #1
trumpetplayer91372
trumpetplayer91372's Avatar
trumpetplayer91372 is an unknown quantity at this point
Send a message via MSN to trumpetplayer91372
Removing Rear Door Panel
Sorry to make a new thread on the subject, but I couldn't find anything relating to my problem. I shut my rear passenger door today and the window dropped about halfway down and when I tried using the switch it made a noise, but the window didn't move, so I just want to remove the panel to see which part is broken. I took out the 2 screws under the handle, but I didn't know if there are anymore screws or if there are just clips holding the rest in. Also, do the 2 paneling pieces come off together or separate because at times they seem to move as one? So if someone can explain how to take a rear panel off I would then be able to see which part is failing and go from there.
trumpetplayer91372 is offline   Reply With Quote
