Old 08-21-2008, 03:37 PM   #1
ndottaylor
ndottaylor's Avatar
ndottaylor is on a distinguished road
Send a message via AIM to ndottaylor Send a message via MSN to ndottaylor
Gas Smell With A/c On
Guys, I need your help...
I started my car the other day and turned my A/C on and within seconds there was a strong smell of gasoline. I turned the air off, waited about 30 seconds and turned it back on. Still the gas smell. So i turned off my car let it sit for a few min and started again with the a/c on... no help. I live in TX and its too hott to be without a/c lol. But this doesnt happen everytime i turn on the a/c.
Does anyone know what's going on? I've never experienced anything like this b4.
The only repairs I've had done lately was having the catalytic converter replaced.
Thanks in advance for any and all help with this
and btw,... its an 01' 2.4
ndottaylor is offline   Reply With Quote
Old 08-21-2008, 03:53 PM   #2
surreal_awakening
surreal_awakening's Avatar
Look for a gas leak?
Old 08-21-2008, 04:17 PM   #3
itsbmw
Umm are you parked when you do this? My cars exhaust gets into it when im parked but when I drive I get nothing.
Old 08-21-2008, 04:24 PM   #4
The smell of raw gas it a leak as will have to be fixed ASAP.
Don't know how fuel is delivered on the 2.4 though. I had a "O" ring go bad in the fuel reg on the 3400
Old 08-21-2008, 04:54 PM   #5
don't know why it would happen only when the a/c was engaged
Old 08-21-2008, 05:03 PM   #6
ndottaylor
ndottaylor's Avatar
Both parked and driving. But it's not all the time.
Old 08-21-2008, 05:03 PM   #7
Me thinks it's the only time he smelt it
Old 08-21-2008, 05:04 PM   #8
ndottaylor
ndottaylor's Avatar
do u know much it would cost if it is the "O" ring? and ill have it serviced tomorrow
Old 08-21-2008, 05:05 PM   #9
It cost me about $40. only took 1/2 hour, if that's the problem
That was on the 3400 thou
Old 08-21-2008, 05:06 PM   #10
why don't you open your hood, and take a damn look at the engine bay and see if there's fuel sprayed all over. it's not that hard. look around the injectors, see wetness.
replacing injectors/o-rings/fuel rail crap is not hard at all and can be done very quickly. the hardest part is figuring out how the heck to unplug the wires.
Old 08-21-2008, 05:07 PM   #11
I did find the point of leaking pretty quick
Old 08-21-2008, 05:07 PM   #12
ndottaylor
ndottaylor's Avatar
That sounds good... but i dont know crap about working with an "O" ring though. hmmm...
Old 08-21-2008, 05:09 PM   #13
In that case, leave it to a pro.
I know carbs not FI systems
Old 08-21-2008, 05:10 PM   #14
ndottaylor
ndottaylor's Avatar
i will do that
Old 08-21-2008, 05:11 PM   #15
Midgear
on vacation
lol.. replacing an O ring is like taking a tiny ass rubber band and putting it around the tip of your finger- its easy as pie.
WILL NEVER FORGET
Old 08-21-2008, 05:15 PM   #16
ndottaylor
ndottaylor's Avatar
darnit... i wish i where more mechanically inclined...
Old 08-21-2008, 05:18 PM   #17
Vinalero
Vinalero's Avatar
Ditto. At least you could check for where the leak is coming if you dont want to repair it yourself. Open the hood, check around the fuel rail, start the car and try to notice if something is leaking somewhere.
Ion, those freaking plugs on the injectors.... UGH!
Old 08-21-2008, 05:25 PM   #18
srsly that's why i'm not putting my Cobalt injectors in yet
1. don't want to have another epic fuel splash
2. don't feel like figuring out how they come off again
meh i know fuel injection but no clue on carburetors, old school, FI ftw
Old 08-21-2008, 05:41 PM   #19
ndottaylor
ndottaylor's Avatar
Ok, so i had my coils replaced a few months back... could it be something with that?
Old 08-21-2008, 06:17 PM   #20
Unless they knocked something loose on the fuel side. The 2 are not connected
If it was a coil probelm, it would run rich or lean and you'd smell it behind the car, not under the hood
