View Poll Results: If you used similar bulbs (Raybrig, Polarg, etc.), what were your results
0%
Voters: 0. You may not vote on this poll
Old 05-27-2004, 12:26 AM   #1
niral622
niral622 is an unknown quantity at this point
I know this has been thrown around a number of times before, but to further clarify since the terms are sometimes confusing
2003 Black GL - Sedan and No sunroof
niral622 is offline   Reply With Quote
Old 05-27-2004, 12:40 AM   #2
It's very simple
low beam max wattage---55
hi beam max wattage-----65
fog light max wattage-----37.5
Anything more will melt the wiring and the plastic socket.
Don't buy blubs on eBay, spend the extra few bucks now and save $300 per headlight housing later
Old 05-27-2004, 06:13 AM   #3
jonez
Just make sure if you are going to use the Japanesse and you want to use the stock wiring that you go with the lower wattage ones. If for some reason where you live doesn't have the low Japanesse ones let me know. They are easy to come by out here.
Old 05-27-2004, 10:33 AM   #4
Grouch
Originally posted by Redog@May 26 2004, 11:40 PM
It's very simple
Actually you can go a bit higher and be okay. For example:
The Sylvania Silverstar headlight bulbs are 60/70 and you can use 55-watt bulbs in the fog lights without a problem.
Old 05-27-2004, 11:53 AM   #5
alero168
I Love Tiara!
alero168's Avatar
alero168 is an unknown quantity at this point
Send a message via AIM to alero168
since when are silverstar bulbs 60 and 70? says 55 on the box
alero168 is offline   Reply With Quote
Old 05-27-2004, 02:22 PM   #6
Grouch
60/70 according to Sylvania's site. I don't recall what's on the box, I thought it said 60 (for the lows). Will look at my boxes when I get home.
Old 05-27-2004, 11:27 PM   #7
niral622
hey jonez:
I have raybrig whitesonics...here's a link:
http://nlmotoring.com/catalog/product_info...products_id/458
they look great! and so far i've had them in for about a month and a half and it doesn't look like anything is melting (when i last checked)...the description says 55watts with "95watt brightness" so i assume they are 55 watts. I cant tell you what it says on the box b/c it's in japanese :rolleyes:
Old 05-27-2004, 11:58 PM   #8
jonez
Yeah have all the same problem, All the aftermarket lights I have but are all Japanesse. Can't read a damn thing.
Old 05-28-2004, 02:20 AM   #9
alerosport.com
I have Plasma glow or something, 100 watt it said... for high beams, bright blue.... had them for around a year, don't use them for more then 40 to 60 min. though.... other wise works fine...
Old 05-29-2004, 12:16 AM   #10
niral622
yeah, i don't use them for more than an hour or two at night....if they melt, then i guess i'll be replacing the harnesses and getting silverstars ....i'll keep them as they are until they do melt b/c i'm happy with them
Old 05-29-2004, 02:32 AM   #11
sound_xtreme
sound_xtreme's Avatar
i have 80/100 and i use them for hours on end. i've probably had the dims on for 4 hours+ before and the highs a good hour or more.
Cardomain
