Old 08-29-2008, 10:40 PM   #1
mfuller
Please help - photoshop request
Inspired by Mr. Mike.....
if anyone has some spare time, could anyone please photshop these wheels:
onto this car:
Old 08-29-2008, 10:49 PM   #2
Midgear
on vacation
I couldn't photoshop if my life depended on it.. but heres mrmikes car with those wheels in a chrome color.. kinda sparks an idea of what those black ones would look like on the black alero..
I bet it'd look sweet.
http://www.aleromod.com/forums/showt...ht=summer+pics
WILL NEVER FORGET
Old 08-29-2008, 10:55 PM   #3
say it ain't so!!! what is the wheel weight difference? I know you are a weight weeny.....
Old 08-29-2008, 11:06 PM   #4
mfuller
No worries......the Kosei's are staying with me.....but I think I will need drag radials.
The ASA's will only be for the street; they're about 6lbs. heavier per wheel. The aluminum front lower control arms help to balance it out.
Old 08-29-2008, 11:19 PM   #5
drag radials, you having problems hooking up lately?
Old 08-29-2008, 11:33 PM   #6
mfuller
Yes....last time at the track, 60' times between 2.6 and 2.8. Trapping nearly 92mph though. Hoping to run 13's and trap above 95 next year.
Old 08-29-2008, 11:35 PM   #7
nice.....what are the specs on your cam and you got some head work done too didn't you?
Old 08-30-2008, 01:55 AM   #8
Old 08-30-2008, 09:12 AM   #9
mfuller
216/224 @ .050", .517.538 valve lift, 112 LSA on the cam.
Heads are WOT-Tech street/strip port with Comp springs/retainers/locks, SI stainless valves, cc's reshaped and matched and flow-match on the ports, decked .020". Heads are basically blueprinted.
Old 08-30-2008, 09:13 AM   #10
mfuller
Originally Posted by natedawg9640 View Post
Thanks Nate; that's exactly what I was looking for.
Old 08-30-2008, 09:57 AM   #11
sounds good, are those valves a bigger diameter than stockers? what springs did you go with? stock ratio rocker arms?
BTW those wheels, at least in the photoshop look real good on your car....
Old 08-30-2008, 11:08 AM   #12
I like the wheels on your car
what side skirts do you have ?
Old 08-30-2008, 11:34 AM   #13
bizarre179
bizarre179's Avatar
bizarre179 is on a distinguished road
Send a message via AIM to bizarre179
They look like razzi skirts.
kim<3
http://www.cardomain.com/ride/2981709
bizarre179 is offline   Reply With Quote
Old 08-30-2008, 11:42 AM   #14
Silentalero
Kitteh is back!!!!
Silentalero's Avatar
this means matt is now gonna go on a 24lb diet
gotta make up that difference somehow
97 Nissan 240sx - sr20det
94 Nissan 240sx convertible
01 Suzuki gsxr 750
Old 09-01-2008, 09:58 AM   #15
mfuller
Stock diameter on the valves; I can't afford custom valves.
Comp 26986 springs and stock 1.6:1 (OEM) rockers. Until the full rollers come out.
Old 09-01-2008, 10:21 AM   #16
Yeah, i will probably end up using stock diameter valves as well, with those springs, the rollers really are exciting though, I am kind of nervous though because even the 1.7s will put me over .600 lift
Old 09-01-2008, 12:07 PM   #17
alerored04
alerored04's Avatar
Do you guys have a guess what the price of these will end up at? I would love to know projected gains off of higher ratio's. Matt you didn't go with the 1393 cam did you? Those specs are different from mine. What changed your mind?
Edit: Now I see, you went with the 1280 grind. How much low end did you lose? I was looking at that one but I feel that my car is weak enough on the bottom already.
My car breaks alot.
Old 09-02-2008, 12:51 PM   #18
mfuller
I think the rockers will probably be comparable in price to a cam, so say maybe $350 or thereabouts.
I went with the 1280 since my heads will flow like the bejesus up top, plus I have 3.42 gears going into my trans to compensate for the low-end loss.
Ben is still working on the heads, an I had him hang onto the cam and everything else until he's completely finished. Hope to have everything installed before next spring.
Old 09-02-2008, 05:48 PM   #19
alerored04
alerored04's Avatar
Cool, now I just need to talk to ben and see what he thinks will work best for me.
My car breaks alot.
Old 09-03-2008, 07:41 PM   #20
mrmike
mrmike's Avatar
mrmike is an unknown quantity at this point
I was originally inspired by derek_ski99's black ar1s on a black Alero:
http://www.aleromod.com/forums/showthread.php?t=13765
mrmike is offline   Reply With Quote
