heat up the silicone seal with a hair dryer or 200*F in the oven. Then just be careful. if you break it, you weren't being careful enough.
Also, there is a "drain" in the headlight assembly. before you take anything apart, make sure that's not clogged. if it's clogged, that's what's holding moisture in.
Originally Posted by black
