Old 09-07-2008, 11:18 PM   #1
jabartram
AutoCross Alero
jabartram's Avatar
Upgraded to HID.
I have upgraded to HIDs thanks to Aftermath, follow link to see pics. you may have to register to see the actual pics?
http://www.nbodypower.com/nbodypower...=2047#post2047
yeah, you will have to register.
Old 09-07-2008, 11:35 PM   #2
AftermathAlero
He has the HID headlights and HID foglights!
thank you sir!
Old 09-08-2008, 12:19 AM   #3
jabartram
AutoCross Alero
jabartram's Avatar
i sent pics to your aim email, sorry but i didnt get a pic of the bulb comparison for reference.
these are 55w HID kits, the low beams were direct plug and play, i had to disable my drls because the bcm limits voltage to the lowbeams in drl mode and it was causing the right side ballast to shut off to protect itself, the drivinglights/foglights were a little harder, the right side ballast would only flicker and caused the 10 amp fuse to pop, so i had to upgrade to a 20 amp fuse and i had to setup a relay for the driving/fog lights due to lower voltage hitting the right side ballast, so it was about a 2 hour install but it was worth it, i have PLENTY of forward lighting.
