Old 09-09-2008, 12:25 AM   #1
bigdaddyD
bigdaddyD is on a distinguished road
Send a message via MSN to bigdaddyD
cold start troubles
i have an 03 with 92k miles on it. when ever i start the car from a cold start it has a rough idle and the car shakes alot. if i put it in reverse it acts like its gonna stall, if i put it in drive it does the same thing but its not as bad, but once i give it some gas in drive it stops. im thinking it might be bad/dirty injectors, ive tried sea foam but it didnt help. any ideas?
Cardomain
GM Tunerz.com
bigdaddyD is offline   Reply With Quote
Old 09-09-2008, 04:07 AM   #2
CactusWill
Thats interesting, seeing as how reverse is the most powerful gear in a car. I'd start out with the basics, like replacing your fuel filter, and go from there.
Old 09-09-2008, 04:29 AM   #3
bigdaddyD
the fuel filter is only a couple of months old, i replaced the spark plugs from bosch plat +2 to ac delco last month and put new wires on to.
Cardomain
GM Tunerz.com
Old 09-09-2008, 05:08 AM   #4
CactusWill
Hmm.... Have you had your codes scanned?
Old 09-09-2008, 05:30 AM   #5
bigdaddyD
i have not i will the next time i pass an az but there are no light on right now
Cardomain
GM Tunerz.com
Old 09-09-2008, 05:32 AM   #6
Midgear
on vacation
try cleaning your mass air flow sensor and intake air temp sensor? did you put the seafoam directly into the throttle body or dump it into your gas tank?
WILL NEVER FORGET
Old 09-09-2008, 10:50 PM   #7
bigdaddyD
i put seafoam in the gas tank crank case and pvc but i will clean the two sensors tomorrow. what do i use to clean them?
Cardomain
GM Tunerz.com
Old 09-09-2008, 11:00 PM   #8
Midgear
on vacation
hell I just had a can of air laying around and blew mine out.. lol
WILL NEVER FORGET
Old 09-09-2008, 11:07 PM   #9
USsnipes
USsnipes's Avatar
USsnipes is on a distinguished road
i have a similair prob. when i start up my car the rpms will go up to around 1k and drop to about 500 and it will do this for a bit until i rev the car or put it in a gear.
2000 Alero GLS Sedan
only mod - CAI
USsnipes is offline   Reply With Quote
Old 09-10-2008, 12:55 AM   #10
rustyballs_69
Its Beer Thirty
rustyballs_69's Avatar
They sell MAF cleaner and throttlebody cleaner at pretty much any auto parts palce.
Old 09-10-2008, 07:20 AM   #11
zzyzzx
zzyzzx's Avatar
Check for vacuum leaks.
Old 09-10-2008, 03:57 PM   #12
-Alero-
-Alero-'s Avatar
clean your idle air control valve, its attatched to the throttle body its the black sensor at the top and held by 2 star screws
AUTOBOT
Old 09-25-2008, 02:45 AM   #13
bigdaddyD
well after having my car scanned for codes, which came up empty, and cleaning the entire engine bay it turns out it was the fuel pump. i would have done it myself but i didnt have the time so i had a shop do it and it set me back $730.
Cardomain
GM Tunerz.com
