09-21-2008, 01:53 AM
Heat/ AC problems
I have a quick question... For a while now, I have only had three speeds working on my ac unit. Medium, medium high, and high. the lower speeds do not work at all. Is this a problem with the controls in the dash, or is it a fan issue? It's not really a big deal, but if it's something small and inexpensive to fix, then I'd like to get it fixed.... So is it the fan or controller?
09-21-2008, 02:06 AM
Dude, I think you are on here for long enough to first : know how to search, and second : know about the blower motor resistor problem with Aleros...
FAIL!
09-21-2008, 02:14 AM
lol I'm tired and half asleep.... sorry... the noob in me is coming out tonight.  I found the part I need.
Close thread please!
09-21-2008, 02:16 AM
the blower resistor is gone on mine, the lower speeds haven't worked in my car for as long as i've had it. i just haven't bought a new one or even bothered to fix it because i hardly ever use it.
99 alero - totalled
96 impreza 5spd awd - sold
09-21-2008, 02:22 AM
It's at most $25 for the part according to rockauto.com....
I'll ask this question then, where is this resistor located, and is it easy to get to and replace?
09-21-2008, 03:06 AM
I replaced the blower motor resistor on mine with a new delco one and the low speeds STILL don't work.
09-21-2008, 03:10 AM
I'm having the same problem, I took apart the controls and tried to clean all the terminals, thinking maybe they were corroded or something, but that didn’t help.
1999, RED Alero GX
09-21-2008, 07:08 AM
i believe its near the firewall, on the passanger side.
i'm absolutely postive there is like 2 how tos on this one.  noobs
09-21-2008, 10:02 AM
09-21-2008, 11:48 AM
blower resistor is located passenger side of the dash, underneath the dash right by the firewall , and allot of the sound proofing material is around it and its a muth effin pain in the ass to get at
i paid 12 buck for mine
09-21-2008, 01:39 PM
hey cavalier.. you should do a video like the posting and you aleromod style
2001 Oldsmobile Alero GL Sedan LA1 3400 SFI V6
Nickname : Midnyte
From that site, it looked like a couple different brands with different prices... I'll most likely just get the cheaper one.... No sense in getting one more expensive that does the same thing. lol Thanks for the heads up bdyman about it being a pain to get to.
02-06-2009, 09:10 PM
Yeah I just did mine this week...What a bitch that was...The bolt closest to the front of the vehicle that holds in the connector was nearly impossible to fit something on ha...took an extension and a swivel for me
02-06-2009, 09:17 PM
Yea, Passenger side behind the carpet half way up the fire wall. It has 2 lil bolts holding it on. Its a PITA to get to and get out, You can get the part at autozone for about 18 bucks.
