Old 09-23-2008, 12:49 AM   #1
umm_i_forget_14
umm_i_forget_14's Avatar
umm_i_forget_14 is on a distinguished road
Send a message via MSN to umm_i_forget_14
Question need help choosing an amp!
alright well im new to the world of car audio and stuff, and i just picked up a pair of JL 10W3v2 and was wondering if any1 would kno of a good quality amp to run them. thx
umm_i_forget_14 is offline   Reply With Quote
Old 09-23-2008, 07:48 AM   #2
Dual 2,4 or 6 Ohms?
http://mobile.jlaudio.com/pdfs/10W3v2_MAN.pdf
Want about 5-600 WRMS...
Old 09-23-2008, 12:29 PM   #3
umm_i_forget_14
Dual 4 Ohm, and i was looking for about 400 wrms, but like i said im new so im just looking for sum advice
Old 09-23-2008, 12:35 PM   #4
budget?
Old 09-23-2008, 12:35 PM   #5
undecided02
undecided02's Avatar
undecided02 is on a distinguished road
srry im an engine guy, but I do know that alpine and MTX make decent sound gear. I would check out thier sites.
undecided02 is offline   Reply With Quote
Old 09-23-2008, 10:00 PM   #6
umm_i_forget_14
budget....im hoping to not pay more then 400
Old 09-23-2008, 10:07 PM   #7
NickAlero2000
NickAlero2000 is on a distinguished road
sony x-plod 1200W amp
got mine free with 2 12'' Polk subs, but expect to pay $200 for it, its a quality amp but not too high end
NickAlero2000 is offline   Reply With Quote
Old 09-23-2008, 10:28 PM   #8
umm_i_forget_14
at 4 ohm that amp only pushes 200wrms to each sub, so not wat im looking for
Old 09-23-2008, 10:49 PM   #9
deathwish666
deathwish666's Avatar
deathwish666 is on a distinguished road
http://www.crutchfield.com/S-XX8WfFV...01&cc=01&wm=cl
i know they are expensive but its 50% off of this amp...
and if you are going to get it pm me and ill give you a referall that will give you another $20 off
EDIT: just saw this one thats more of what your pushing for...a little over 400rms and a little over $400...but its still a kick ass deal
00 alero
so far: jvc cd player, sony xplod speakers, jl 1000/1 amp
2 12" kicker cvr, wai, green underglow
coming soon: some led's, better subs
deathwish666 is offline   Reply With Quote
Old 09-23-2008, 10:55 PM   #10
in my opinon sony car audio just isn't that good.
www.techronics.com
have at it, there or crutchfield. btw, i see ur new. just so you know ryan is THE go to guy om here for audio systems.
Old 09-24-2008, 07:31 AM   #11
lmao...
You have dual 4 Ohm subs...
Run them parallel and present a 1 Ohm load. Dont be an idiot and go higher...
This allows you to get a good amp at a cheap price and power them properly.
Your choices wired into 1 channel are 1 ohm or 4 ohm and to get an amp to push 4-600 WRMS X 1 @ 4 ohms is going to cost some serious cash.
400 is small also. 500 wrms min or more... they will handle upwards of 700 WRMS...
Old 09-24-2008, 11:54 AM   #12
mach3
mach3 is on a distinguished road
First of all you need to decide what is your intention for these subs. ie to show off, audio competitions or just every day comfortable listening levels with some decent punchy bass.
If you don't plan on craking it to the max for everyday driving, one good amp with 400 WRMS will be plenty of power to feed those two subs. I'm running two 600WRMS amps to power my two 1000WRMS subs and that is still enough juice to blow my brains out. The alt. is going to give out before the amps will.
If you are going with high wattage amps, you need to consider the thickness of the power and ground wires as well. If you plan on istalling it yourself do more research first.
check these guys out, they have everything from entry level to top of the line products.
www.onlinecarstereo.com
mach3 is offline   Reply With Quote
Old 09-24-2008, 12:30 PM   #13
DansGen1Alero
DansGen1Alero's Avatar
DansGen1Alero is an unknown quantity at this point
Send a message via AIM to DansGen1Alero Send a message via Yahoo to DansGen1Alero Send a message via Skype™ to DansGen1Alero
I love JL Amps, I got a 1000/1 but then again I am also pushin 3 JL 12-w6 version ones with dual 6 ohm coils
1000 watts baby, and i love it, but that amp would be too much for you, and ur w-3s and its also 999 new, I got mine as an open box from tweeter for 729, but it had a faulty ground and they replaced with a brand new one woo hoo, this is in my lexus, my alero as an alpine v-12 expert, 1000 watts pushin the same 3 12 w-6 version 1's. thats a damn good amp too.
may be able to find a used one for 400 and turn the gain down halfway.
www.myspace.com/dansgen1alero
www.nicedreamscc.com
"Vinyl belongs on the side of a house not on a car"
DansGen1Alero is offline   Reply With Quote
Old 09-24-2008, 06:23 PM   #14
umm_i_forget_14
okay so i need a mono amp stable at 1ohm with a min of 500wrms and then just wire the subs parallel which would give me a 1 ohm load and then it should work fine? is that about right or am i still way off lol
Old 09-24-2008, 06:36 PM   #15
DansGen1Alero
i wouldnt go down to 1 ohm, very risky and I dont think the w-3 could handle it, 4 ohms should be fine maybe 2
Old 09-24-2008, 10:38 PM   #16
www.bcae1.com
Please read up before giving improper advice.
The sub is a dual 4 Ohm sub, which means it can be wired for 2 or 8 ohms. Wiring between both subs then will give you 1 or 4 ohms.
"The subs cant handle it"? You have got to be kidding me... That is what the subs are made for. Theres no way you can wire those 2 subs to get a 2 Ohm load.
Options:
1 X 1 Ohm
1 X 4 Ohm
2 X 2 Ohm
2 X 8 Ohm
4 X 4 Ohm
There are no other options.
OP. Yes 500-600ish WRMS @ 1 Ohm is what to look for.
Old 09-25-2008, 01:03 AM   #17
Ian 2000GL LA1
Ian 2000GL LA1's Avatar
Ian 2000GL LA1 is on a distinguished road
Send a message via AIM to Ian 2000GL LA1
e-Bay a nice used rockford there great with JL. i put a newer rockford fosgate P300.1 on an older JL 12W6 with the bass knob thats the best used $300 setup (for the brand used) that i have ever put together. it went into a 2000 tauras and it Friggin rattled some panels in that i was shocked for just a 12 and i was always skeptical about how great JL's were.
they have an amazingly crisp and clear bass.
but then again i watched a W7 pop at a DB comp the other day, the only thing to crapp out, and i aslo saw yesterday 3 older 10w3's that were being rapped by an infinity amp and the kids like oh yeah there like this all the time , and ther 8 years old. idk what it is mabe there a difference between the old and new in endurance.
life story over...
Ian 2000GL LA1 is offline   Reply With Quote
Old 09-25-2008, 01:57 AM   #18
umm_i_forget_14
alright thx alot guys, between everything said here and the research i've done i think i have a pretty good idea of wat im looking for, if anything goes wrong i'll deff hit you guys up.......alero's ftw!!!
Old 09-25-2008, 07:07 AM   #19
Stop by and let us know what you intend to buy exactly. Might be able to save you some heart ache if you start eyeing a junker...
Old 09-25-2008, 07:47 AM   #20
DansGen1Alero
Originally Posted by Ryan from Ohio View Post
www.bcae1.com
Options:
1 X 1 Ohm
1 X 4 Ohm
2 X 2 Ohm
2 X 8 Ohm
4 X 4 Ohm
Bro, they only handle 300 rms
http://mobile.jlaudio.com/products_s...php?page_id=15
And If I am not mistakin the 1 ohm stable amps can be a little pricey, but that was years ago I a not sure if prices for amps have gone down.
but do what you want to, ill butt out
