Old 09-24-2008, 03:24 PM   #1
Colllin
Colllin is on a distinguished road
amp on/off
how do i hook up my amp to the Remote turn on/power antenna wire so that the amp turns on and off when the radio does?
Colllin is offline   Reply With Quote
Old 09-24-2008, 03:32 PM   #2
AGT
AGT's Avatar
You can run the remote wire directly to the radio "remote" and splice or you can wrap it around a fork of the fuse for the radio in the fuse panel.
Have a good day
Old 09-24-2008, 03:45 PM   #3
You got an aftermarket radio or stock?
Old 09-24-2008, 03:48 PM   #4
AGT
AGT's Avatar
clutch has a good point. If stock radio you can just go with the radio fuse in the panel.
Have a good day
Old 09-24-2008, 03:59 PM   #5
itsbmw
I ran mine off a inline fuse to a switch I mounted in the dash by the little holder thing by your left knee im thinking about running it off the radio because when I turn off the car without flipping the switch off i get crazy feedback and it hurts :'( Also coming home at 11pm and then shaking every house around you isnt very polite
Old 09-24-2008, 07:16 PM   #6
My sound system isn't done yet, but I Ran my remote wire (When I installed the deck) to the one coming out of the deck.
I didn't know it could be done another way. haha.
Old 09-24-2008, 07:39 PM   #7
Yea, if it's aftermarket you'll want to hook it up to the red wire going to the deck, or the designated "remote" wire, which is usually blue. Some decks turn the sub amp off via an option built in, which is when you'd want to use the designated remote wire for sure.
If you're using a stock deck I usually tap into the harness behind it.. take a tester (one bought for this task, or an LED/resistor or something that runs on 12v), ground out on side of it, poke the lead into the hole on the harness of wires that look probable (usually either thicker ones, or red/yellow, or both). Turn the key to accessory and if your tester lights up, use that wire, if it doesn't, keep testing wires. Make sure the tester goes off when the key is turned off, otherwise your amp will be on all the time.
Never done the fuse thing before.. but if you do just make sure the fuse loses power when the key is off.
Old 09-24-2008, 07:43 PM   #8
bizarre179
bizarre179's Avatar
bizarre179 is on a distinguished road
Send a message via AIM to bizarre179
^ If done the wrong way and you route to a constant 12v wire, your battery will die in no time.
kim<3
http://www.cardomain.com/ride/2981709
bizarre179 is offline   Reply With Quote
Old 09-24-2008, 07:46 PM   #9
bryan213
bryan213's Avatar
bryan213 is on a distinguished road
just pull the radio out and tap onto the red power wire and run it to ur amp turn on that simple
bryan213 is offline   Reply With Quote
Old 09-24-2008, 10:28 PM   #10
Colllin
i have a stock deck
Old 09-25-2008, 01:06 AM   #11
Ian 2000GL LA1
Ian 2000GL LA1's Avatar
Ian 2000GL LA1 is on a distinguished road
Send a message via AIM to Ian 2000GL LA1
idk where the fuel pump wires are but in a taurus i spliced in into the fuel pump switched in the trunk, that saved about 10 feet of wire.
Ian 2000GL LA1 is offline   Reply With Quote
Old 09-27-2008, 01:55 PM   #12
Colllin
I'm a bit confused can someone tell me in more detail how to run the wire through the fuse access and one more thing where is the best place to hid the wires?
