10-01-2008, 06:47 PM
Something wierd happened
Ok so today driving home from work i made a turn and all of sudden my stereo turned off and all kinds of lights came on the console like brake, trac control, security, and service engine soon and the car was still running. what causes this? I just drive home like normal and shut the car off. Im afraid to try and start it now. Should I be worried?
10-01-2008, 06:50 PM
go try starting it and let us know what happens? you may have blown some kind of fuse or have a short somewhere.
2000 Chevrolet Malibu LS
10-01-2008, 06:53 PM
Trying to get it together
Might be alternator going wonky. Have your alternator check for voltage. Should be between 13.7-14.5 volts and current at 105 amps. Generally the voltage drop caused a sudden triggering of all the electrical warning lights, kills the acessories. The vehicle is setup to alway draw at least battery voltage to power the essentials system (PCM, ECU, BCM, DIS). HAve that checked first.
MODS:???
10-01-2008, 09:45 PM
just started it up everything back to normal i have a feeling this wont be last of it though
10-01-2008, 11:30 PM
do you have radio controls on your steering wheel?
10-02-2008, 12:46 AM
ima go ahead and say your alternator or connections are shot, and that's about it
check voltage as said
smirking is important
follow the titans
10-02-2008, 01:02 AM
you prolly filled with premium and now youre going to blow up.
10-02-2008, 04:10 AM
Did you use a can of compressed air, turned upside down, to repair a dent in your fender??
10-02-2008, 03:35 PM
lol you guys are hilarious. Car runs fine still have all the lights and no radio. i think Im going to disconnect the battery and hook it back up so everything resets.
10-02-2008, 04:40 PM
make sure the connections are tight on the battery
10-02-2008, 08:11 PM
... And on the Alt to be sure.
10-02-2008, 09:23 PM
what are you talking about? Aleros dont have radio controls on the steering wheel.
