Old 10-13-2008, 05:41 PM   #1
RickM380
RickM380 is on a distinguished road
3.4 trouble
I have a strange deal going with my 99 alero with a 3.4. Only when I fill the car with gas, the car will not want to start. I have to hold down the gas, maybe 1/4 throttle for it to keep running. After I get going, it is fine and will idle like it should. Anybody ever hear of this?
RickM380 is offline   Reply With Quote
Old 10-13-2008, 06:00 PM   #2
kniedelm9490
kniedelm9490's Avatar
kniedelm9490 is on a distinguished road
Send a message via AIM to kniedelm9490
ive had it once or twice it went away
kniedelm9490 is offline   Reply With Quote
Old 10-13-2008, 07:12 PM   #3
Hrmmm, That's odd. Fuel filter issues or something? That's kinda shady, not too sure.
Old 10-13-2008, 07:29 PM   #4
Midgear
on vacation
seafoam it and buy new sparkplugs for it lol
ACDelco Rapid Fires = 20 - 30 bucks
WILL NEVER FORGET
Old 10-13-2008, 10:37 PM   #5
CactusWill
Sounds like theres alot of built up sediment in the bottom of your gas tank that is getting stirred up when you fill the tank, and once it gets stirred up then the sediment is getting sucked onto the prefilter in your tank.
I would say that replacing your fuel filter should definately help, as well as some fuel system cleaner as mentioned might help as well. You may not get it perfect, but as long as it runs better without spending an arm and a leg then you have circumvented the problem for the time being.
Old 10-14-2008, 09:11 AM   #6
RickM380
I replaced the spark plugs and wires in june, and I just replaced the fuel filter and used some fuel system cleaner, and put some gas in it and it did the same thing, just not as bad.
I knew it needed the fuel filter because I looked at it and it was the original one that came on the car.
Does the fuel pump have a regulator by chance?
Old 10-14-2008, 10:29 AM   #7
CactusWill
I don't believe so, but could be wrong.
