Old 10-16-2008, 08:03 AM   #1
CBLOHM3400
Trying To Help
CBLOHM3400's Avatar
CBLOHM3400 is on a distinguished road
Send a message via Yahoo to CBLOHM3400
Bulldog RS1100 Car Starter
I have search for this but no luck finding the answer so here it goes
I installed a bulldog rs1100 car starter tuesday and have one problem that i can't figure out : door locks show a one wire system
when i wire it up per instructions it does nothing the unit just clicks
I call bulldog and got conventily out on hold for ever. So i thought that i would ask to see what you guys think
thanks chris
03 OLDS ALERO
CBLOHM3400 is offline   Reply With Quote
Old 10-16-2008, 08:35 AM   #2
I suggest visiting their website and looking up the info on your car.
They have a very comprehensive website for the DIY crowd.
You have to have a bypass module. Also if you have a way to get their T Harness its saves a TON of time. Theres some resistors and possibly a relay involved here.
Old 10-16-2008, 08:40 AM   #3
CBLOHM3400
Trying To Help
CBLOHM3400's Avatar
i have the bypass module the car starts trunk opens lights falsh heater blows everything works except the door locks
i have printed everything to do with my car off bulldogsecutriy.com
03 OLDS ALERO
Old 10-16-2008, 08:41 AM   #4
CBLOHM3400
Trying To Help
CBLOHM3400's Avatar
also i have wired the res. with correct ohmage into the system like instructions say and still nothing
03 OLDS ALERO
Old 10-17-2008, 03:22 AM   #5
jwateland
jwateland is on a distinguished road
have you brought up a wiring diagram for your door locks? find you power and your ground that is commonly used by all of locks
jwateland is offline   Reply With Quote
Old 02-19-2009, 12:44 PM   #6
forty6and2
forty6and2's Avatar
forty6and2 is on a distinguished road
door locks are negative through a 1500 ohm resistor.
the wire is white in the big black plug in the kick.
bulldog might have a strong enough negative signal to make em work .. so you may need to wire in a couple relays.
and as for a bulldog.. i wouldnt even waste my time throwing it in the garbage.. i hate that junk
i knew a guy once that pressed his starter button on the fob and his truck went up in flames
forty6and2 is offline   Reply With Quote
