Old 11-14-2008, 01:54 PM   #1
ryanthefizz
ryanthefizz's Avatar
ryanthefizz is an unknown quantity at this point
Will these fit
will these 5.25" fit in my front doors? 2001 coupe, and i know I will have to run new wires because monsoon is well... special.
http://www.crutchfield.com/App/Produ...ures_and_specs
ryanthefizz is offline   Reply With Quote
Old 11-14-2008, 02:06 PM   #2
Alero_1986
Alero_1986's Avatar
Alero_1986 is on a distinguished road
not without modification. The factory speakers are 4x6
Alero_1986 is offline   Reply With Quote
Old 11-14-2008, 02:08 PM   #3
ryanthefizz
yes i realize that, but i hear modding for 5.25" is very minor... any details on how minor?
Old 11-14-2008, 02:11 PM   #4
Alero_1986
Alero_1986's Avatar
talk to Ryan. he had a couple of 5.25 adapters for sale on the forums.
http://www.aleromod.com/forums/showthread.php?t=24536
Old 11-14-2008, 02:11 PM   #5
Rexter9x
Rexter9x's Avatar
Rexter9x is on a distinguished road
If you have the monsoon the fronts are 5.25 with tweeters in the sail panel. So you might not need a adapter plate or you wont have to make a baffle for it.
Rexter9x is offline   Reply With Quote
Old 11-14-2008, 02:16 PM   #6
ryanthefizz
for monsoon equipped alero's does the door panel look different, or do they all look like 4x6s?
Old 11-14-2008, 02:52 PM   #7
Rexter9x
Rexter9x's Avatar
All the door panels should look the same, the mounting plate for the speaker is the only difference as far as I know.
Old 11-14-2008, 07:25 PM   #8
ryanthefizz
so i looked and i have 4x6's up front.
think these will sound nice?
http://www.crutchfield.com/App/Produ...00&i=107DB461P
http://www.crutchfield.com/App/Produ...300&i=1086937I
Old 11-14-2008, 07:32 PM   #9
darksobsession
darksobsession's Avatar
darksobsession is on a distinguished road
Send a message via AIM to darksobsession
i have the infinitys. they're nice, but you have to have a place to put the crossovers.
sigs are annoying
darksobsession is offline   Reply With Quote
Old 11-14-2008, 07:37 PM   #10
ryanthefizz
what did you do or what would you suggest?
Old 11-14-2008, 08:15 PM   #11
Rexter9x
Rexter9x's Avatar
I would suggest you grab a set of the 5.25 adapters from another alero with a monsoon, of make some mdf baffles for either a 5.25 or 6.5 set of components. Toss the tweeters in the sail panels and your good to go.
Old 11-14-2008, 08:32 PM   #12
ryanthefizz
i am liking the 6.5 component idea
Old 11-14-2008, 08:35 PM   #13
i've had a bunch of issues with my 6.5s... check depth. cuz its certainly can become a HUGE issue. (mine with adapters, are tight against the window, and still about 1/8" away from the door...which is what tore my first pair)
if your going for 6.5s its better to have someone (or DIY) a set of fiberglass speaker pods to fit over the stock location.
Old 11-14-2008, 08:44 PM   #14
ryanthefizz
i was gonna put the 6.5s in the back...
another question, my deck puts out 52 watts RMS and the polk 4x6's im looking at are rated 4-50 (150 peak)... the 52 watts is too much?
Old 11-14-2008, 09:41 PM   #15
Rexter9x
Rexter9x's Avatar
Your deck is putting out more like 18watts, not the 52 that they advertise.
Old 11-14-2008, 10:17 PM   #16
ryanthefizz
anyone know the specs on the monsoon amps? can i use that to power these component 6.5s?
http://www.crutchfield.com/App/Produ...7DB6501&tp=106
Old 12-19-2008, 04:14 AM   #17
nickgonzo
nickgonzo is an unknown quantity at this point
Just wondering how deep are your mids? How did you mount them? Got pics?
Just wondering because I took my panel off yesterday and was very dissapointed to see what I have to work with. Does any one know (in inches) the biggest baffle we can bolt to door without hitting door panel.
nickgonzo is offline   Reply With Quote
