Old 06-06-2004, 12:16 AM   #1
Sportalero
Standard set up: 3157 and 194 bulbs in front turn lights. 3157s in rear. Make a right turn, signal blinks normal. Make a left, and it flashes faster than the tits of a drunken sorority slut at Mardi Gras. But when I hit the hazards, they blink the same speed. I would guess the fuse, but since it controls both sides, and the right blinx normal, im stumped. Any clue as to what to do?
Old 06-06-2004, 12:37 AM   #2
smokinAMD
Are you sure one of the bulbs isn't burned out? Normally they blink fast to indicate that you have a burned out bulb.
Old 06-06-2004, 12:37 AM   #3
Aleromaster
Aleromaster is an unknown quantity at this point
Send a message via AIM to Aleromaster Send a message via Yahoo to Aleromaster
yeah turn on the left blinker and check that all your bulbs on the left side are good
2002 GL2 4DR, MYMODS:In dash 7&quot; VGA Widescreen monitor, XM Satalite Radio, Clarion Amp, 2 10&quot; Audiobanhn DVC Subs Hidden HitchTrailer Hitch, Grill Mesh
Aleromaster is offline   Reply With Quote
Old 06-06-2004, 12:53 AM   #4
Sportalero
Yeah, all bulbs are go. And i forgot to add, the 194 bulbs (outer) don't blink or run at all during night time. This didn't start til the day after the rain storm we had. I mean the "trees-down, power-out-all-over-town" type storms. Maybe water got into a connection somewhere, but i have no idea where to look :unsure: .
Old 06-06-2004, 01:16 AM   #5
bigd6983
look at all relays, fuses, and wiring that hasta do with those lights......start with the bulbs, the fuses, then relays.......last check the wiring........you can always do a continuity check, just get some extra wire and run from where the fuse is to the electrical connector to rule out bad wiring.......
Old 06-06-2004, 01:41 AM   #6
dadirtybulldog
my guess would be that you're starting to have the infamous hazard switch problems... if so, be prepared to replace it :thumbsup:
Old 06-06-2004, 02:46 AM   #7
Sportalero
Got the hazard switch fixed last year, dirty. Along with the "dead" cruise control button.
Old 06-06-2004, 05:41 PM   #8
FormulaNERD
how did you fix the dead cruise? mines dead too....
i had this blinker problem when i put the 3157 LED's in the rear, try puttin normal bulbs in and see if this fixes the blinker problem.
Old 06-06-2004, 06:00 PM   #9
Nikatrel
Haha, i always have fun signaling with my hazards... ppl dont know which way ya turnin!
Old 06-06-2004, 10:43 PM   #10
Sportalero
I still had my warranty, so i took it the dealership. But all it was was one of the wires was faulty and they replaced it. Shouldn't be over 50 bux. Probably could get it done cheaper (or free) at a shop. It's a small problem.
And i found the blinker problem. One of my many "spliced" connections got some water and rusted apart. Just snipped the rust, rewired, and water-proofed the hell out of it. :thumbsup:
