12-10-2008, 06:31 PM
Manual Transmission Fluid
I am changing my transmission fluid along with other repairs currently on the go. Wondering what others with the F23 are running.
GM recommends Dextron III Automatic Transmission Fluid for the Getrag F23 transaxle. However, a few members of J Body Ontario have had pleasant experiences with MTF synchromesh.
Originally Posted by spddmon
I have just switch trans fluid to Amsoil MTF Syncromesh, and it is hands down the best fluid I have used. Whether hot or cold it shifts the best.
For comparison I have also used:
Regular dino ATF was too thick cold and too thin hot.
Mobil 1 syn ATF (for about 20K) and found it way to thin. Very notchy, hard to get into reverse and I had to double clutch to get into first when downshifting from second.
Royal Purple Syncromax was a great improvement from the Mobil 1. Smoother and easier to get into gears. I accidently spilled some when an axle popped out doing a ball joint, and I was surprised to notice that it had significantly darken over the 15K it was in the tranny. I mean it was black, all the other fluids (regular ATF, Mobil 1 ATF, and Amsoil ATF) came out looking brand new even if they had more miles on them.
Amsoil syn ATF was the only thing I could find on a Sunday afternoon after I spilled the Royal Purple. This fluid worked ok but alot of the Mobil 1 characteristics return. I just find syn ATF is just to thin.
I realize that GM recommends ATF for the Getrag but there is also a bulletin to use syn Syncromesh in the Getrag if you experience trans rattle. Plus Amsoil MTF syncromesh viscosity is only slightly thicker than ATF but nowhere near as thick as gear lube (i.e. Redline MTF). For reference RP viscosity is almost the exact same as ATF. Amsoils is also a GL4 lube unlike B&M which is a GL5 which can cause excellerated wear of brass components.
12-10-2008, 06:33 PM
Can anyone see any potential ramifications of running the synchromesh? or should I just stick with a Dextron III compatible synthetic ATF
12-10-2008, 06:39 PM
on vacation
Dextron III Automatic Transmission Fluid for a manual transmission?
WILL NEVER FORGET
12-10-2008, 06:41 PM
You learn something new everyday, huh?
Yup, Owners manual even says so.
12-10-2008, 06:42 PM
DO NOT CHANGE THE TRANNY FLIUD ON A MANUAL TRANSMISSION!!
The only time you change the fliud on a manual, is when there is a rebuild, manual tranny fliud is more like a lube than fliud
12-10-2008, 06:44 PM
on vacation
^ that's what I was thinking.. manual fluid is more of a lube.. some people refer to it as gear oil rather than tranny fluid
WILL NEVER FORGET
12-10-2008, 06:53 PM
thanks for the advice, but I'll let you do your own research
12-10-2008, 07:07 PM
^^ Have fun
12-10-2008, 07:14 PM
^^ Have fun
I don't want to start an argument over this, but I would rather if people did not post in regard to procedures to which they have no knowledge of.
I understand the point that you are trying to make here. I do not feel the need to get into the discussion around the benefits of changing your vehicles fluids. If you have interest, feel free to do some research. Thanks for your time though.
12-10-2008, 08:31 PM
Dude your tranny is as good as gone if you put ATF >>>AUTOMATIC Transmission Fluid in there.
Unless your having trouble with is I'd leave it alone.
ATF was proven long ago to not have sufficient shear strength for use in a manual transmission. That's why the transmission manufacturers switched away from it, though it used to be specified during a time transmission manufacturers were trying to standardize on just one lubricant.
12-10-2008, 08:42 PM
FOR THE RECORD! ATF comes in getrag F23 trannies on both n-body and j-body from the factory.
When changing the fluid for one reason or another, switching to the saturn synchromesh is a perfectly viable option. There was even a minor bulletin about consumers complaining about a noise in the tranny, the solution was to switch to synchromesh.
ADDITIONALLY. Using Redline MTF is fine as well on the Getrag tranny.
Why? Because I've been there, searched, talked, inquired, reaffirmed, backtracked, looked backwards, spelt shit backwards.
12-10-2008, 08:43 PM
either that or that or Redline equivalent to synchromesh
12-10-2008, 08:44 PM
^^ Have fun
You sound like his tranny will asplode if he changes the fluid.
12-10-2008, 08:46 PM
on vacation
what's wrong with changing the fluid in the transmission.. be it manual or automatic? how can this cause harm if done regularly?
WILL NEVER FORGET
12-10-2008, 08:49 PM
Yep That's the good thing to do, Saturn Fluid FTW. I did it as well and I worked at a GM Dealership and checked for that bulletin about noise... and also asked to the transmission guy in the place. It helped to reduce the noise alot
12-10-2008, 10:28 PM
Thanks for the opinions guys. I think I'll go with the Amsoil synchromesh as I had originally thought. I may also check a price on the Saturn fluid for comparison.
12-10-2008, 11:10 PM
FTW.....
12-11-2008, 03:06 AM
Is that the same Synchromesh fluid that came in the 282s from way back when? (#12345349)
There's also a Friction Modified Synchromesh (#12377916)
From what i gather, the Saturn fluid used to be a completely different part number.
Also, You can use Dexron III for your F23, but under NO circumstances use Dexron VI. GM *SPECIFICALLY* states this and now sells "Manual transmission fluid" which is just Dexron III just for the manuals that require it.
I know the Redline MTL was praised in the 282. However the original synchromesh is all the hype with the honda, acura, subaru, mitsubishi, etc.. owners.
12-11-2008, 08:41 AM
lol, i was just about to ask this, saturn is a bit low on manual fluid.....thanks again, i was not going to put ATF in my car because of the fact that its not an AT!!
12-11-2008, 05:47 PM
but ATF works.
