Old 01-05-2009, 12:32 PM   #1
rocker_boy55
rocker_boy55 is on a distinguished road
Power!
if you have a deck(head unit) that is rated 50x4 watts but you only put two speakers on it. will it give the two speaker 100 watts max power each or will you just loose the other 100 watts.
.same for a four channel amp (4x25), if you only put two speakers will it still be 4x25 or 2x50
rocker_boy55 is offline   Reply With Quote
Old 01-05-2009, 12:51 PM   #2
u will lose the power unless the channels are bridged together and i don't know how to do that on a HU. U can on a amp pretty easily tho. wait till some of the hardcore audio guys come in like ryan and they will tell u for sure.
Old 01-05-2009, 01:21 PM   #3
itsbmw
I'm going to say no on bridging because wouldn't that be mixing 2 channels together? And I don't know how the amps in the HU put out the power if only 2 speakers are plugged in.
Old 01-06-2009, 02:14 AM   #4
nickgonzo
nickgonzo is an unknown quantity at this point
To answer your question, no you will still only get the rated power from each channel of the head unit. (Good luck getting 50wrms)
Secondly, on an external amp you can bridge channels 1 & 2 and channels 3 & 4 and that will usually double your watts depending on the amp.
For example: An amp that does 25w x 4 @ 4ohms will usually do 50w x 4 @ 2ohms. If you bridge this amp it will put out 50w x 2 @ 4 ohms. Also do not bridge a HU internal amp.
nickgonzo is offline   Reply With Quote
