Old 01-26-2009, 10:26 AM   #1
Alerosaint
Gone but not forgotten
Alerosaint's Avatar
Alerosaint is on a distinguished road
Send a message via AIM to Alerosaint Send a message via Yahoo to Alerosaint
Valves would not seal
Okay over the weekend me and a buddy finished replacing the bad piston I had. We put the engine back together.
Problem:
No compression still in #4 cylinder.
What was done:
Did a compression check got no reading
Pressurized #4 cylinder and felt air coming out through the throttle body
Remove s/c manifold, re-pressurized and heard and felt the air seeping from the valve seat area
What was found: After spraying WD40 on both intake valves would not seal
Anybody have any ideas??
Alerosaint is offline   Reply With Quote
Old 01-26-2009, 10:31 AM   #2
im gonna go out on a limb and say your leaking from somewhere
Old 01-26-2009, 10:59 AM   #3
resurface the valves.... maybe when you detonated you burnt the intake valves
Old 01-26-2009, 10:59 AM   #4
Alerosaint
Alerosaint's Avatar
yeah the intake valves for #4 is not closing all the way
Old 01-26-2009, 11:02 AM   #5
so was the valve scored? or was the spring just worn form you bouncing in the 7 - 8K RPM range?
Old 01-26-2009, 11:24 AM   #6
Alerosaint
Alerosaint's Avatar
yeah they were black
Old 01-26-2009, 12:13 PM   #7
Oldsman
Owner
Oldsman's Avatar
if this is a push rod motor it is one of the following
-bend push rod
-bad lifter
-bad valve spring
-bent valve
-bad valve seat
I would remove the head do thorough check of the head
Beware of the BackStabber
