Old 02-05-2009, 07:34 PM   #1
white04alero
white04alero's Avatar
white04alero has a little shameless behaviour in the past
head lights
I will soon be clearing my head lights and I have a scuff on one from when my sister wrecked in to me. How do I go about gettin scuff out? I am assuming sanding with some kind of plast x or something?
2004 Olds Alero GL1 3400 V6
- pioneer 4900iB head unit
white04alero is offline   Reply With Quote
Old 02-06-2009, 11:10 PM   #2
white04alero
nothing?
Old 02-06-2009, 11:51 PM   #3
NickAlero2000
NickAlero2000 is on a distinguished road
go to the bazaar for sale, white liquid is looking for headlights in exchange for his ones, cleared, and bezels painted white
if ur car is white, as your username describes
NickAlero2000 is offline   Reply With Quote
Old 02-07-2009, 01:00 PM   #4
white04alero
lmao. im not replacing my headlights, im repairing them genius
Old 02-07-2009, 01:10 PM   #5
ya if ur sister "wrecked" into your car i doubt its just a scuff on your headlight but im sure you could try sanding them from like a 300 grit and up and then polish it with something, not sure if that would work but you could give it a go
Old 02-07-2009, 01:55 PM   #6
Vinalero
Vinalero's Avatar
Ive used some fine grit on my headlight one day because I wanted to remove some scratches on them (cant remember but it was like 800 or 1500) and all I did was making the plastic looking more dull. I would not touch the headlights with sandpaper. But you know maybe its me that is completely unskilled with sandpaper.
Old 02-07-2009, 08:08 PM   #7
NickAlero2000
but you said you're clearing them, so im pointing you in the direction of someone who has already cleared them, and who i think wouldnt care about a scuff.
Your welcome.
Old 02-26-2009, 09:47 AM   #8
Xtrm
Xtrm's Avatar
Xtrm is on a distinguished road
Send a message via MSN to Xtrm
You can also get what is called a Micromesh kit. it works really well. i use it at work on aircraft windows (wich are made of Lexan).
2003 Alero GLS 3.4L
Xtrm is offline   Reply With Quote
Old 02-26-2009, 10:11 AM   #9
NickAlero2000
n00b zombie! back from the dead rises the thread!
Old 02-26-2009, 10:20 AM   #10
acctually thankyou! i was about to start repairing my headlights! im gonna look into that!
it was valid information, i liked it and im sure many more will too
Old 02-26-2009, 03:24 PM   #11
Xtrm
Xtrm's Avatar
hey no problem.
2003 Alero GLS 3.4L
