02-17-2009, 09:10 PM
Where should I....
Hook up the power for my gauges in the fusebox thing if I only want power when the car is on?
02-17-2009, 09:19 PM
Just below the gauge cluster you can tap into the pink Ignition power wire. Fuse it if you want.
02-17-2009, 09:40 PM
anywhere in the engine bay though :-/ cause I already have the wire running there...
02-17-2009, 09:51 PM
Idk about the engine bay.. Theres ignition fuses under there but I've never tapped them for anything, or even thought about it.
02-17-2009, 09:52 PM
damn ok thanks :-) I'll just pull it back through
02-18-2009, 08:38 PM
ok well... this is still open cause I dont want to pull it back through anyone know of somewhere I can hook it in the interior fusebox or the engine bay one that it will only be on when the car is.
02-18-2009, 08:46 PM
pcm fuse on the left driver's side panel
02-18-2009, 08:50 PM
I shall go try
02-18-2009, 09:22 PM
Originally Posted by xXMahanXcorEXx
I shall go try
proceeds to make PCM explode. lollol
02-18-2009, 09:28 PM
it might.... hes been known to cut out perfectly reasonable parts, on the account that someone told it "it'll run better"
02-18-2009, 09:29 PM
^thats wat the fuse prevents.
just test the fuses under the hood til u find one thats only on with the key.
02-18-2009, 09:50 PM
If your consider a huge flow restriction on the exhaust to be a perfectly reasonable part than sure.. I guess I cut off perfectly reasonable parts. False! I cut it off because no one is going to catch me in freaking Indiana and I know like 10 kids at my school who run their cars catless.
02-18-2009, 10:01 PM
^so ur fitting in with a crowd? typical. cats have extremely little efect of performance, and taking one off will decrease ur gas milage. if u really hate stock get a high flow. u can look right through them.
02-18-2009, 10:04 PM
cutting out your PCM makes it FAST!
02-18-2009, 10:15 PM
I never cut out my PCM?
i'm suggesting it.... it works!
no?
but all the cool kids do it!!
still no?
damn.
02-18-2009, 10:16 PM
cherrington17: cutting out your PCM makes it FAST!
There's a wire on the pcm, that if cut will, lead you to shift hard  lol I left B&M in shame. Happened to me during my audio install jk
02-18-2009, 10:24 PM
rofl. valley... thats.. just...wow..... NICE!
