Old 02-20-2009, 12:08 AM   #1
irondiezl3
irondiezl3's Avatar
curb weight
my vin lookup says my car weights over 4000 pounds? wtf is that? i thought we had same frame and similar weight to gagts? they have 3300 curb weight thats a huge difference!
Old 02-20-2009, 12:15 AM   #2
it weighs 2985 ish somewhere around there
of course depends on what it's equipped with
Old 02-20-2009, 12:19 AM   #3
CactusWill
Look on your title. Mine says 2927 lbs, thats with a 4 cyl. With a V6 model, you'll be 1-2 hundred lbs more.
Old 02-20-2009, 12:38 AM   #4
irondiezl3
irondiezl3's Avatar
title says 3016. that sounds better phewww whatever that crap the dealer pulled up was way off!!
Old 02-20-2009, 12:57 AM   #5
03alero2.2
03alero2.2 is on a distinguished road
it should be on the piller of your drivers side door or on the door its self
03alero2.2 is offline   Reply With Quote
Old 02-20-2009, 01:19 AM   #6
Vinalero
Vinalero's Avatar
Im at 1300
... KG on my title :P
Old 02-20-2009, 03:46 AM   #7
Curb weight.
Weight of the vechile with a full tank of gas, every seat filled, and a trunk full of cargo.
Mine tipped the scales at 3340 and Jackels at 3327 when we raced
Old 02-20-2009, 09:00 AM   #8
Originally Posted by Redog View Post
Curb weight.
What? No it isn't, lol.
Curb weight is the total weight of a vehicle with standard equipment, all necessary operating consumables (e.g. motor oil and coolant), a full tank of fuel, while not loaded with either passengers or cargo.
Old 02-20-2009, 11:14 AM   #9
sounds more like it.....
Old 02-20-2009, 12:12 PM   #10
irondiezl3
irondiezl3's Avatar
whats a spare tire setup drop when taken out around 20 pounds?
Old 02-20-2009, 12:28 PM   #11
Vinalero
Vinalero's Avatar
Spare and jack, you are looking around 40 pounds
Old 02-20-2009, 12:58 PM   #12
Beholder88
Beholder88's Avatar
Beholder88 is on a distinguished road
What do they say, you gain something like 1 hp per pound you shed off the vehicle? Something like that...
Beholder88 is offline   Reply With Quote
Old 02-20-2009, 02:38 PM   #13
NickAlero2000
NickAlero2000 is on a distinguished road
Vehicle curb weight has nothing to do with horsepower.
For every 100lbs you shed from your vehicle, you lose 1/10 of a second in a drag race.
NickAlero2000 is offline   Reply With Quote
Old 02-20-2009, 02:39 PM   #14
NickAlero2000
Example. your car + you weighs 3100lbs. You run 13.5. You remove your spare tire and backseats, dropping 100lbs from your vehicle. You then run 13.4, theoretically.
Old 02-20-2009, 03:08 PM   #15
Beholder88
Beholder88's Avatar
I think that's what I meant. I know I've seen time studies somewhere on that.
Old 02-20-2009, 03:13 PM   #16
Vinalero
Vinalero's Avatar
If only it worked like that
Nick is more right, but the gains are not constant if you keep removing weight, at one point the wind resistance catches you.
Old 02-20-2009, 05:02 PM   #17
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
and I wish the back seats were 60 pounds...they are so light, that taking them out would have hardly any effect on the drag strip. (maybe .01 faster, at the most.)
Old 02-20-2009, 11:56 PM   #18
Spare and jack = 50 lbs.
This is going to be the first year I'm NOT dumping the spare/jack or switching the intake to race, at least in the points, I'll still do it for the sport compact days
I dropped the spare and jack in the Delta when it still had the 307 and it went from 20.20 to 19.98
Althought I just found out a few weeks ago that that motor was probably really out of tune because a 98 with a stock 307 motor ran 18.90 and that car weighs about 200 lbs more
Old 02-21-2009, 05:44 AM   #19
Spilner521
Boost Guru
Spilner521's Avatar
Damn, you might need a full cage soon...
