Old 02-21-2009, 11:14 PM   #1
AtomicX
AtomicX's Avatar
Code P0133 after Header install
Hey I put a pacesetter header on my Alero. I had to extend the o2 wire, but I did it very carefully, didn't just throw some electrical tape on it and call it a day. I made it so its just enough to reach the plug, but with a little slack so it doesn't yank on the wire. Well I'm now throwing the P0133 code which is a slow response from the o2. The wiring looks perfectly fine, could the o2 be messed up?
Old 02-21-2009, 11:16 PM   #2
it's farther away from stock, it responds to the combustion that happens in the engine slower
get a heated O2 sensor
Old 02-21-2009, 11:38 PM   #3
AtomicX
AtomicX's Avatar
Doesn't the heated O2 sensors have 4 wires when the regular one has 2?
Old 02-21-2009, 11:45 PM   #4
yep, so you tap into the rear o2 sensor's heater wires so power comes on when the car comes on
Old 02-21-2009, 11:58 PM   #5
KenshinZero
KenshinZero's Avatar
KenshinZero is an unknown quantity at this point
Thats all it takes?
1999, RED Alero GX
KenshinZero is offline   Reply With Quote
Old 02-22-2009, 11:05 AM   #6
well, yeah o_O, get the universal BOSCH O2, comes with posi-lock connectors, works great.
i'm not sure why our engine's don't have the upstream heated stock, the eco's do. you get to closed loop ultra fast with heated lol, and it's more accurate and switches quicker.
Old 02-22-2009, 07:47 PM   #7
AtomicX
AtomicX's Avatar
Did anyone else get this code after their header install?
Old 02-22-2009, 07:51 PM   #8
Caboose73
i did i just did what ion said
Old 02-22-2009, 07:55 PM   #9
it's a slow response, so either your O2 sensor is getting bad (the signal switching slows down over time as it wears out), or it's that your sensor is too far away, or both.
the solution for both problems is using a heated O2. it's like $55.
Old 02-22-2009, 10:11 PM   #10
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
me too...and I got raped on a replacement sensor...they put a brand new OEM sensor in on Thursday and the light just came back on!
so where do I find this heated O2 sensor? (either online, or in the store...I know where on the car. )
Old 02-22-2009, 10:17 PM   #11
AtomicX
AtomicX's Avatar
Autozone should have them, check their website to see if their available for your zipcode.
Old 02-22-2009, 10:28 PM   #12
AlbinoMonkeyRat
Let's Play Army!
only product I get is overkill:
http://www.autozone.com/selectedZip,.../selectZip.htm
Old 02-22-2009, 10:35 PM   #13
AtomicX
AtomicX's Avatar
Bosch / Oxygen Sensor
Note: Universal
4 wire; heated
Pricing:
$59.99
http://www.autozone.com/R,508495/veh...ductDetail.htm
that seems fair
Old 02-22-2009, 10:52 PM   #14
AlbinoMonkeyRat
Let's Play Army!
ahhh...I searched for "heated o2 sensor" not "oxygen sensor". I'll check the store tomorrow. If it's not there, I'll buy online. Thanks
Old 02-23-2009, 12:03 AM   #15
15732 is in fact the part number I use.
Old 02-23-2009, 12:43 AM   #16
AlbinoMonkeyRat
Let's Play Army!
Thanks for clearing that up.
