Old 02-28-2009, 11:05 PM   #1
03alero2.2
03alero2.2 is on a distinguished road
grinding noise ???
so im driving done the road and hear a grinding noise and i replaced both wheel bearings and the breaks are good any ideas
03alero2.2 is offline   Reply With Quote
Old 02-28-2009, 11:17 PM   #2
itsbmw
e-brake
Old 02-28-2009, 11:23 PM   #3
Originally Posted by itsbmw View Post
e-brake
sounds about right
Old 02-28-2009, 11:35 PM   #4
dragon8807
dragon8807's Avatar
dragon8807 is on a distinguished road
Send a message via Yahoo to dragon8807
this bracket might be the source of the grinding noise, i had the same problem after doing my brakes
just bend it away from the rotor and you'll be good
99 alero - totalled
96 impreza 5spd awd - sold
dragon8807 is offline   Reply With Quote
Old 03-02-2009, 04:30 PM   #5
03alero2.2
neither i looked at it today in shop class anything els that could be causing it?
Old 03-02-2009, 04:52 PM   #6
Beholder88
Beholder88's Avatar
Beholder88 is on a distinguished road
Is it coming from the front end for sure, or does it sound like it's coming from the rear? Could be a bunch of things. Does it go away when you are turning, get worse?
Beholder88 is offline   Reply With Quote
Old 03-02-2009, 05:26 PM   #7
XanderWiFi
XanderWiFi's Avatar
calipers seized against the rotors? Just had the same problem myself...
Old 03-03-2009, 04:12 PM   #8
03alero2.2
it gets worse when i trn left so im thinking that it somming from the right is it possible that i got a bad wheel baring
Old 03-03-2009, 04:30 PM   #9
Beholder88
Beholder88's Avatar
You know what, it could be your halfshaft. Check the boots closest to the wheels for tears. Usually if you get a tear though you'll get grease flung around your wheel well. If it's worse when you're turning that could be the culprit.
Old 03-03-2009, 04:54 PM   #10
03alero2.2
i hope not but ill look at it in the shop
Old 03-03-2009, 05:28 PM   #11
Beholder88
Beholder88's Avatar
If the boots aren't torn, you might have to actually take them out to be able to tell if they are bad. I would get some new boots and grease just in case. You might have to go as far as taking the boot off to see any signs of extreme wear or breakage.
